How do i find out rear axle - Ford Powerstroke Diesel Forum
Old 01-18-2011, 04:40 PM
Like the title states how do I find out what rear axle I have in my 2006 F-350 DRW
Old 01-18-2011, 04:51 PM
Inside of the drivers door is a build sticker, just below where is says axle there will be two numbers or a letter and a number. Letter and number is Limited slip two numbers is standard rear end. Post the code and we can tell you the ratio.
Old 01-18-2011, 04:55 PM
Here's a link to an older request check post 6 for the codes
Where can I find out which rearend I have?
Old 01-18-2011, 05:00 PM
4N is 4.10 LIMITED SLIP is that good ratio
Old 01-18-2011, 05:02 PM
That would be the standard ratio for a F350 dully but lucky for you they did the option for limited slip.
Old 01-18-2011, 05:09 PM
yeah thats a good towing gear. do you have stock size tires?
Old 01-18-2011, 05:20 PM
Under axle on my sticker, it says F2. What does that mean?
Edit: Nevermind. Found that it shows limited slip 4.1.
Old 01-18-2011, 05:22 PM
245/75/17 on the truck tires are pretty worn any recommend that I should look at
Old 01-19-2011, 08:28 AM
Mine says C1 what would that be?
Old 01-19-2011, 08:37 AM
3.73 limited slip
