Block Heater - Ford Powerstroke Diesel Forum
Old 01-18-2011, 12:12 PM
Block Heater
Well I've never used my block heater and it's in the 20's at night so I figured why not give it a try. I found the cord that comes off the block and it goes up to the front of the bumper. I got this, but my question is from there do I just plug in a regular extension cord?
Old 01-18-2011, 12:18 PM
I don't know nuttin....
Yes, go to Lowes and get you an outdoor 20 amp rated timer to plug the cord into and set it to come on a few hours before you go to work and this will save you on the electric bill instead of leaving it on all night. 3-4 hours in the morning before you leave will warm it up good.
Old 01-18-2011, 12:26 PM
Cool, thanks for the quick reply...
Old 01-18-2011, 12:41 PM
Country Cadilac
Like he said, if you get a timer make sure its rated for 20 amps. I made my own timer from a industrial rated dial timer. I pluged mine in last night and set it to be on for 4 Hrs., when I started my truck the coolant temp was 91* with a outside temp of 20*.
Old 01-18-2011, 12:47 PM
Almostdunfukinwidit
Also make sure the cord is capable of sustaining 20amps.
Minimum of 14ga on a 25 ft 12 gauge on a 50 foot or longer
Old 01-18-2011, 01:07 PM
Yeah, that too. It doesn't pull 20 amps but it pulls close to 15 and will melt a timer not rater for 15 amp. But my cord is 14 ga and 100 feet long and I've had no problem with that.
Old 01-18-2011, 01:09 PM
Almostdunfukinwidit
14ga cord at 100 ft will either melt to **** normally or trip a GFCI.
That same scenario just cost a guy I know a 2008 Dmax and a garage
Old 01-18-2011, 01:12 PM
Well heck, maybe its 12 ga...i have used it for this a long time and it doesnt get hot or anything. I don't have GFI plugs in the shop. It doesn't look big enough to be 12 though?
Old 01-18-2011, 01:14 PM
Almostdunfukinwidit
What color is it?
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
12 gu 100ft cord for 3 hours when i use the block heater,
