What if any are the differences in the 05 and 06 6.0 engines? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 01-17-2011, 01:49 PM Thread Starter
Strokewitpower's Avatar
Getting ready to buy a new truck. Always been a 7.3 guy cause of all the 6.0 problems but I like the pedal response of the 6.0. Not to mention the newer interior and exterior. Without a bunch of mods the 7.3 won't have the pedal and the interior would have to be replaced. My question is is there a difference at all in the 05 and 06 6.0? What should I anticipate in immediate mods such as egr delete?
2010 F250 CC King Ranch
Stock all the way
2001 F350 CC Lariat DRW
Superchip tuned
1996 F250 Regular Cab 4x4 Automatic
6637 Intake
Gone! Thank God
2006 F350 CC Lariat
My other Diesel 1996 315cl 7038hrs with thumb
Strokewitpower is offline
post #2 of 22 Old 01-17-2011, 02:03 PM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
There was a change from 18 to 20mm headbolts in trucks manufactured after Jan '06. Other than that, the '05 and '06 are basically the same. The standard 6.0L mods apply equally to both. Mines in the shop now, due to oil cooler failure and head gaskets (an '07). Immediate mods, the best thing I suggest is do whatever you want with the EGR (I'm going with the one from Bullet-Proof Diesel, most folks here say delete the bugger) and switch to a silicate-free ELC. I've learned from my neglect of this problem.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #3 of 22 Old 01-17-2011, 02:13 PM Thread Starter
Colo sorry to hear it's in the shop. That's what worry's me everyone says they stay in the shop with the 6.0. What's the deal with thegaskets I always hear about the gaskets but never hear about the root problem.
Stock all the way
Superchip tuned
6637 Intake
Gone! Thank God
2006 F350 CC Lariat
post #4 of 22 Old 01-17-2011, 02:18 PM
Unapologetically American
2006PSDSD's Avatar
Quoted: 24 Post(s)
Feedback Score: 4 reviews
Benjamin hit the nail. I'm still up in the air about the ELC's though. Plenty of vehicles have gone many miles with the Ford gold stuff. I did hear, that once you hit 100k or so, the silicates start to drop out of the mix, and then clog oil coolers. The BPD stuff is top notch, whether you want to delete the EGR cooler or keep it. If you do find a need for replacing the EGR cooler, spend the extra cash and replace the oil cooler at the same time, because it's very likely that it is the culprit for popping the EGR cooler
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #5 of 22 Old 01-17-2011, 02:19 PM
The Silent Service
Quoted: 10 Post(s)
Alright root problem is this, the oil cooler is a oil-coolant heat exchanger. Very narrow pathways for the coolant to go and then flow into the EGR cooler. The Ford Gold Coolant, clogs these pathways with silicate deposits and gunk (reason for the coolant filter) when the oil cooler clogs, it deprives the EGR of coolant flow. The seals fail in the EGR (requiring its replacement) and leak coolant in the engine. The coolant flash-steams and vents out the head gaskets and degas bottle. That's my understanding of the issue in a nutshell, and I'm not a mechanic.
My cooler lasted only 64k, and I've known some bearly break 20k, its a bit of a crap shoot. The oil cooler gives one known indication prior to failing like this, and its not monitored from the dash. You'll need an Insight or gauges, and watch EOT/ECT a spread of 15 degrees, and take her own for an oil cooler.
post #6 of 22 Old 01-17-2011, 02:20 PM
2006PSDSD's Avatar
Quoted: 24 Post(s)
It can be caused by too hot of a tune, but in his case, it's probably the EGR cooler that popped and let coolant in the cylinders and then lifted the heads that way
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #7 of 22 Old 01-17-2011, 02:22 PM
The Silent Service
Quoted: 10 Post(s)
Yeah, that's the other thing. Some 6.0L Owner's are tuner-happy, and push things a bit farther than they probably should.
post #8 of 22 Old 01-17-2011, 02:24 PM
I have a 06 F-250 with 155k miles on it. I havent had any real major issues except EGR valve replaceced and injector #1 replaced. I plan opening up the exhuast and getting a CTS to montior everything. Im still up in the air on doing the Collant filter kit,BPD EGR cooler and oil cooler since I havent had any issues yet. other than the truck is great! Pulled a 24' gooseneck down I-10 going 80 and forgot i had the trailer back there loaded.
2006 6.0 PSD 4x4 SWB CC Cat delete with 6 inch tip.
coalburnertx is offline
post #9 of 22 Old 01-17-2011, 02:40 PM
Fox'sFord's Avatar
These motors love clean fluids, run a good 5w 40 synthetic oil all year. Put a coolant filter on, and get gauges or a monitor. The 6.0 is not fragile, in the 106xxx I've had mine no egr/oil cooler issues, my temp difference is never more than 4 degrees. It is however a higher maintenance motor.
Fox'sFord is offline
post #10 of 22 Old 01-17-2011, 03:00 PM Thread Starter
If the coolant itself starts the problem off would another coolant eliminate the problem? Everyone, I know with one has done the delete so there must be no way to stop it. I am very apprehensive about getting a 6.0. Somebody give me some kind of reassurance. Sounds like it's the same as owning a BMW. Damn oh well I'll just take it as it comes.
Stock all the way
Superchip tuned
6637 Intake
Gone! Thank God
2006 F350 CC Lariat
