High Idle?
Stooopid question of the day.....
2004 f350 w/6.0. On cold days like today, when I start it up, she'll run great and idle in the normal idle RPM range (cannot remember but its like 700 or 800 perhaps). If in park and provided my foot isn't on the brake pedal, after a minute or 2, she'll throttle up to about 1000ish rpm. Once I depress the brake, it idles back to normal. Only happens on cold days...not in the summer or warmer temps. This truck is stock (no tunes, etc). Is this the high idle mod that has been referenced in other threads? If not, what is, then, the high idle mod and why does the mod exist? |
No that is normal and the computer is doing that because the air intake temp is low. The PTO high idle takes the RPM to 1200 and it requires the emergency brake.
Not true, I'm not sure what model years, but I know my 04 does not need to have the parking brake engaged. I hit the switch and leave.
Also to the OP that is normal, nothing to worry about...
Fair enough... I have an '05 and that is how mine works.
03/04 does not need the brake
07 does not need the E brake applied
It is completely normal. You may hear an airy sound like the turbo wastegate is stuck open if you try to drive it while it is cold, and that is the exhaust baffle off the manifold. It closes to create more pressure on the engine while it is idled up to help warm the engine and compartment to help bring everything to a safe normal operating temp. It happens to my 7.3 if the engine oil temp is lower than 60ish and the air intake is say lower than 40ish. Let it idle up like that for 5 minutes or so and you should be fine to run it normal.
well, lets brake it down. its actually a PTO Idle Control that is Pre-wired into your harness under the dash that you can wire a toggle switch in with the corresponding return wire that the PTO would normally hook up to and poof! high idle on demand! but Ol' EmoMover forgot that this is a forum for helping other powerstroke owners out to the best of ones abilities. sorry your 6.0L buddy wouldnt tell you that you can make your own high idle control and that the cold idle is normal...besides, why should someone so knowledgeable share his brains when he can feel superior!!!? sorry OP for putting you in the middle of this, but hopefully you found some answers... as for the baffle that the 7.3 has to create pressure on the engin, i do not know if your 6.0 has that, but like ol leadhead said, its a 6.0 not a 7.3...
