Truck running on after turned off - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-13-2011, 02:36 PM Thread Starter
Quoted: 6 Post(s)
I keep getting more details on this truck i bought. Its a 2003 i am working on and was parked when the previous owner tried to shut it off and it kept on running and at a high rpm withthe key off. By the time he went to get a wrench to disconnect batteries it stopped running on its own (about a minute). Thats when i bought the truck (not knowing this at the time). I bought the truck as having a bad engine. It was locked up and wouldnt turn over. We drained the oil and got over 14 gallons out of it mostly diesel. We found that the engine was hydrolocked when we went to turn it over by hand to get to the converter bolts and by turning it backwards we were able to clear the cylinders and it now turns over freely. This engine i have since found out has only 18k on it and is a Ford reman replaced by ford. I am starting to wonder if it is actually a good engine with something incidental causing it to run on and then drain a bunch of fuel into the oil pan. Regardless i am still replacing the engine with another but would like to find out a cause to what might have created the problem so i know its not something that will happen to the new one. Also how would one go about checking out the old engine to see if it is still viable now that it is out of the truck? Thanks
DENALI is offline
post #2 of 9 Old 01-13-2011, 04:08 PM
Quoted: 118 Post(s)
If my memory serves me right, when you posted this earlier I noted that one or more injectors were probably injecting into weak cylinders and instead of the fuel being compressed and ignited during the compression stroke, worn or broken rings caused the fuel to slide down the piston walls and into the block.
Since you noted that there was 14 gallons of diesel in the oil, the oil was probably like watery soup and hence when the motor was turned off (fuel supply from the injectors shut down), the oil flowing thru the motor was so watery that it was passing thru the valve guides, pistons, rings and everywhere thereby allowing some further combustion post shut off.
Remember that diesels do not require an electrical ignition source. Provided they have fuel, air and compression that generates heat and ignition, the motors will keep running. I've seen tractors where the turbos have gone out pumping engine oil (which is used to lubricate the turbo) into the air intake and despite the fuel being shut off, the engine would rev uncontrollably until the block was drained of the oil. That, my friend, is one scary thing!
I would say you definately have tear down the motor and check for wear on each major component (e.g. crank, journals, etc). If the motor was ran for an extended period on the oil/diesel mixture, you probably have at minimum wear on the cylinders, etc.
Just my 2 cents.
jd4010 is offline
post #3 of 9 Old 01-13-2011, 04:32 PM
flint_smoke's Avatar
Has the truck ever had a programmer on it?
04 Harley Davidson F250
Muffler/Cat delete
SCT w/Matts SRL
3" leveling kit
33" Toyo Mt's
Airaid intake
flint_smoke is offline
post #4 of 9 Old 01-13-2011, 05:01 PM Thread Starter
Quoted: 6 Post(s)
Not that i am aware of. It was owned by a geo physical company nearest i can tell and the guy that owned it before me drove it exactly 12 miles after he bought it before it went bad.
DENALI is offline
post #5 of 9 Old 01-13-2011, 05:07 PM
'Merica
thecaptin's Avatar
sounds like it has chit some injector(s) and is gonna git expensive.
Jay
*04 Lariat CCLB 4x4
449RWHP 8/25/12 Montana
*08 Lariat CCLB 6spd 4x4
"Stock" 229RWHP DPF On
*L99 Lariat ECLB 4x4
305RWHP 6/20/13
*03 Ranger XLT 4x4
4.0 5spd Flatbed Wheeler
Originally Posted by Galaxie View Post
(Government says)Whats good for you is good for all but not good for me. Just like Obamacare and everything else.
thecaptin is offline
post #6 of 9 Old 01-13-2011, 09:33 PM
Ironmover's Avatar
Just my 2 cents.
True but these engines rely on electric fuel pumps and electronically controlled injectors. I would think some crazy phenomenon happened where at least two different components/systems failed simultaneously to cause the alleged run on. I say alleged cause thats the story that was given to DENALI and now he tryin to sort out the pieces to this puzzle.
Stock sucks
More torque pleeze
21st century participant of the 2nd amendment
Republican
Ironmover is offline
post #7 of 9 Old 01-14-2011, 05:35 AM
Quoted: 118 Post(s)
Totally agree with you! My train of thought was with having soooo much fuel in the crankcase that however it was getting in combined with the pressure being built up in the crankcase was causing just enough fuel to enter the chambers for some firing. I doubt it was running "perfectly smooth" but it would be enough to keep it turning over until the pressure in the engine reduced enough that the fuel was no longer entering the cyclinders.
I think regardless, DENALI has a mess on his hands!
jd4010 is offline
post #8 of 9 Old 01-14-2011, 06:12 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I'd start by doing a compression check and pulling the injectors.
RIP Mitch
the Org crew
PGreenSVT is offline
post #9 of 9 Old 01-14-2011, 10:56 AM
Ironmover's Avatar
Yea good possibility it was a shaking and knockin pretty good.
Stock sucks
More torque pleeze
Republican
