Lets talk ICP and DC%
What should Injection control pressure and duty cycle be at a given RPM?
Say at idle, cruising speed and rev limiter. This would be a stock truck. What about mildly tuned? Race tuned.....? |
Stock truck (except for PHP tuned FICM).
IPR should be around 22-24% DC at hot idle; up to maybe 30% but that maybe a little too high. My ICP is around 580 psig then. IPR should be around 84% DC when cranking. I believe my ICP is about 1900 psig when cranking IPR should be around DC 15% KOEO Last edited by bismic; 01-13-2011 at 06:55 AM. |
That is right on line with what I am seeing stock tuning.
Several times when I have been pulling the trailer up a grade, I have seen 85% IPR and ~4200 psi ICP when datalogging in my tow tune. I don't usually datalog when I am daily driving with my race tune in.
And that is why you are a slacker.
The most I can get is 3600ish at 74% |
![]() Sounds like a high pressure oil leak. Have you updated your STC fitting to the one-piece design and verified your dummy plugs? Your pump should do at least 4000. How many miles now? |
At least 4000 when? That 3600 was normal driving, not holding it at high rpm.
248,000 on the truck. I haven't did anything the stc fitting or dummy plugs |
![]() If that is max when you are getting on it in your race tune, it's probably just fine! |
Whoops.
That's the max I hit when I am just getting on it with stock programming. Im not having a problem, but thought it would be a good discussion topic. Last edited by Goose350; 01-13-2011 at 09:09 AM. |
And I'm the slacker!!!
![]() BTW, what's the difference between PSI and PSIG?
| Tags |
| dc%, icp |
