07 6.0 possible purchase - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-12-2011, 11:05 AM Thread Starter
97workhorse's Avatar
Exclamation 07 6.0 possible purchase
My brother in law is about to buy a 07 f350 6.0 srw with less than 100k on it to use for his landscaping business (haul wood, bobcat, trailers ect.). I have a 97 and dont know much about these 6.0s and wanted the org. opinion on what he can expect from this truck.
97workhorse is offline
post #2 of 4 Old 01-12-2011, 11:09 AM
AlwaysStrokin''s Avatar
It's been hit or miss with them but it seems like the later modeled trucks 05-07 had less problems. And if your not going for big horse power numbers they are good trucks.
There are some things on here you can do to make sure they stay reliable. I'll let the experienced owners tell you about that stuff.
2002 F-350 Crewcab LB XLT
Quad-Pillar Isspro II Gauges, Dp-Tuner: Stock, Hi-Idle, 40Hp Tow, Decel, 80E, 100Hp
4" MBRP Exhaust, T-500 HPOP, AFE II Intake, HID's, Recon Light Bar, Custom Running Boards, Custom Bumper, HPx, FRx
AlwaysStrokin' is offline
post #3 of 4 Old 01-12-2011, 02:06 PM
1. Get a Oasis report from ford this will tell you if it is a problem child any repairs by ford.
2. Check for white stuff around the degasing tank if you see any even around the battery it is pucking coolant (may be HG, EGR cooler, oil cooler) see if they will give him so warranty look for leaks around the back of the motor if so may be the bed plate. Look for any white smoke at start up may be a bad EGR cooler, does it idle smooth take it out and see what kind of boost it makes norm around 24-25lbs at WOT run it don't just drive it
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #4 of 4 Old 01-12-2011, 04:41 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Read the links in my signature.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
