Truck Surgery - Ford Powerstroke Diesel Forum
Old 01-12-2011, 07:38 AM
Truck Surgery
My truck is all apart since the headgaskets blew 2 weeks ago. It's under warranty. However, I'm still paying $1200 in upgraded ford parts/labor and $900 in performance parts The ford parts are little things that the mechanic told me ford has made changes too. Since its apart, the labor is 1/8 of the cost. I added ARP studs, Victor Gaskets, 6.4 banjos, egr delete, ELC coolant and new Ford FPR which ups the psi from 50 to 65. Anything else I should do while its apart? I can't afford injectors at this point and I have a Powermax on order, hopefully.
Old 01-12-2011, 07:49 AM
STC Fitting
Upgraded Turbo Feed & Drain Tubes
Drill & Tap Manifold for EGT Probe
Oil Cooler (Still good?)
Upgraded Oil Cooler Screen
Make sure to have the heads checked for cracks & flatness; machined if needed.
Old 01-12-2011, 10:56 AM
I would also add upgraded dummy plugs and standpipes
Old 01-12-2011, 11:07 AM
I forgot to ask, what upgraded Ford parts you putting on? The 6.4 Banjo's & FPR setup should only cost about $80.
Old 01-12-2011, 12:12 PM
Anyone have some part #'s for these?
STC Fitting
Upgraded Turbo Feed
