Exhaust Smell In Cab - Ford Powerstroke Diesel Forum
Old 01-10-2011, 05:45 PM
So when I am sitting at a stop and have the A/C on I seem to be able to smell exhaust. It isn't over powering and isn't always there but I'm wondering if this is normal or might I have an exhaust leak? Never smell it when I am driving down the road or have the AC off.
Old 01-10-2011, 05:48 PM
Feedback Score: 3 reviews
Up pipes leaking, and/or Y pipe. They are prone to cracking at the bellows.
Old 01-10-2011, 05:55 PM
I think I smell (bad analogy) a reason for a new exhaust system.....can you say 4" turbo back????
Is the y pipe a pain to get to?
Old 01-10-2011, 06:05 PM
NOT a Democrat
Is this all the time? I will get the smell when my truck is first warming up (if unpluged like leaving work). Very small amount and only when it is sitting warming up in a parking spot.
Old 01-10-2011, 06:09 PM
Reading material, post #5.
Where is the Y pipe?
Old 01-11-2011, 08:08 AM
Could also be warped/leaking exhaust manifolds.
Get under the truck and look for black soot marks near seals and joints in the exhaust piping. Start where the manifolds bolt to the head, and work your way back to the turbo.
Old 01-11-2011, 11:58 AM
I have the SAME problem! I can see the black soot on the left side of the engine, but I haven't been able to see the origin of the leak. However, I suspect is this Y Pipe,
Who sells them besides OEM Ford? Or they are not that expensive?
Thanks
Old 01-11-2011, 01:04 PM
Thanks
Here is some reading material that might help you make a decision.
Aftermarket Y-pipe Liberator vs Innovative vs ??
Old 01-11-2011, 02:22 PM
I had that issue a while back and found the fuel filter o-rings were installed wrong. Replaced the fuel filter and o-rings again and the smell went away. I thought it was an exhaust smell, but apparently it was a fuel smell.
Old 01-11-2011, 03:46 PM
Lilpooh
Thank you for the link!!
