2006 6.0 oil capacity - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-10-2011, 02:51 PM Thread Starter
I just bought a 2006 super duty and just changed the oil, it took a full 20 quarts. Did Ford offer a bigger oil pan on some of the powerstrokes. When I put the 16 quarts that I thought it took, it didn't even register on the dipstick. It doesn't look like a aftermarket oil pan so I'm kind of scratching my head on this. Anyone have any info on this???
Thanks
Kuhns07 is offline
post #2 of 11 Old 01-10-2011, 03:06 PM
You should only be adding 14-15 quarts. Do you have an oil bypass filter system added on or a bulletproof oil cooler? If not, you might just have a bad dipstick.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is online now
post #3 of 11 Old 01-10-2011, 03:14 PM
Deere Diesel Man's Avatar
Feedback Score: 4 reviews
yea something is a little off. It should only be 15qts
IF its not a Deere, It must be a Puss!! Livin the Old Age!
2011 F250 Bone Stock
Deere Diesel Man is offline
post #4 of 11 Old 01-10-2011, 04:08 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
Drain at least 5 quarts out. If you can post a pic of the oil pan please do so.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #5 of 11 Old 01-10-2011, 04:27 PM Thread Starter
I'm going to the ford dealership and see if there replacement dip stick matches mine. THat sucks if I have to drain I use Royal Purple! Stuff isn't cheap
Kuhns07 is offline
post #6 of 11 Old 01-10-2011, 04:30 PM Thread Starter
This maybe the first time anyone has asked this question, but does anyone know approx how long the dipstick should be?
Kuhns07 is offline
post #7 of 11 Old 01-10-2011, 05:21 PM Thread Starter
Another quick question, is the dipstick a T handle on the end or a loop? From the ones I've looked up they all have T as the handle and on my truck it's a loop
Kuhns07 is offline
post #8 of 11 Old 01-10-2011, 06:27 PM
sounds like you have a aftermarket dipstick. Get you a stock one from ford and don't drive your truck there. Measure with the proper dipstick and go ahead and get ready to remove a lot of oil.
obsidian is offline
post #9 of 11 Old 01-10-2011, 07:14 PM
Galaxie's Avatar
drain 5 out, get a stock dipstick, you will be fine. DONT get rid of that oil!!! Use it in something else! lol
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #10 of 11 Old 01-11-2011, 07:48 AM Thread Starter
So that's exactly what it was, some jack wagon put the wrong dipstick in. It was about 2.5" to short.
Thanks for all the help.
Kuhns07 is offline
