EGT Probe Hole
Okay, so I'm selling my EGT probe off my Insight and ordering some DiPricol analog gauges (Fuel, Trans, Boost, EGT). I already have a buyer, and I don't have my new gauges yet.
My question is this: Is there something I can put in place of the EGT Probe for a while? I can't drive around with a hole in my manifold LOL. Any tips for removing the EGT probe? I don't wanna strip my threads. |
thread in style or clamp style?
Thread in.
when u pull it out thread a little bolt in there for the time being thats what we did in my friends scummins
What size do I need to look for? Is it gonna melt under high temps?
1/8" NPT plug, pick one up cheap at any local parts/hardware store.
As for "tips" on removing the probe............ Well, I hope you used anti seize when you initially installed it. If not, try hitting it with a little penetrating oil (cold exhaust, of course) |
And what do you mean by anti-sieze? Like Loc-Tite? (Sorry, I'm an internet mechanic. ) And I'll try some WD40 or some PB Blaster on it.
something like copper grade anti seize or silver or what not. All auto parts should carry it.
When i put in my original EGT probe, i failed to do that, played hell trying to get a plug threaded in there had to tap out the hole just a wee bit more to get my plug to set in. Now it has anti seize and when my EGT probe shows up (any day now ) i will have no problem with the R&R
Lowes / homedepot may be a better bet.
well, Loctite makes an anti seize , Anit-seize prevents galling, seizing and corrosion, used in hi temp applications usually. Makes later removal, MUCH easier.hit it with the PB Blaster when cold, and get a little hi-temp anti seize when you're at the store, use it on the new probe. |
