How Long Is a Long Crank
So I just bought my first diesel....2005 F250 6.0 with just over 100k on the ticker and I am sure this will be one of many noob questions. (I already did a search as well and haven't found a definitive answer......)
What exactly would you all consider to be a long start time? I live in an area that temps have been running low 40s down to low 20s. My start times when it is upper 30s and warmer or when the truck is warm seem to run 2-5 seconds. When it is really cold, in the 20s they seem to be more like 5-10 second range. Is this acceptable? I don't plug it in and when it first starts it seems to idle kind of rough for just a couple seconds then smooth out. Just want to see if these are all acceptable numbers and conditions..... |
my first diesel as well so i dont know. but mine takes 2-5secs when warm and 5-10secs when cold, i dont ever crank longer than 15secs so i dont do any damage to the starter, seems like a long crank compared to a gasser but probably normal for diesels
thats what mine does as well...think its normal, iam gonna try to rev x, seems alot of people have a great sucess
That sounds about right. I just recorded a video the other day when I switched oils so I could compare the difference between the two. Just skip 50 seconds in.
That's what mines sounding like. I'm running Rotella T5 10W30 and Rev-X additive. It's definitely helped out with my cold start as well as injector stiction. I used to get a little bit of a rough start or chugging, but that's gone now. Was about 35-40 *degrees and no block heater. Might want to check out this thread, 6.0 oil analysis on Rotella T-5 10w-30. You will probably like this. Last edited by rajjr89; 01-08-2011 at 04:39 PM. |
You may want to try rev-x. Or a different oil weight. Last edited by smokersteve; 01-08-2011 at 05:10 PM. |
I have a fuel issue so thats part of the problem but 7.3 and 6.0 probably have differences in starting as well. |
no thats good
I just changed the oil to the T5 10w-30 in the hopes it would help the cold starting time.....doesn't seem to have helped anything as of yet. I am up in the northern part of the state and it will be in the single digits tonight, real test will be in the morning since I am not planning on plugging it in.
Is there any issue with adding the rev-x a few hundred miles after the oil change? |
There is no issue with adding rev-x at all. |
