looking at 07 psd
I was hoping I could get so info on the 6.0s. I have had a 97 7.3l for 14yrs now and looking a 07 with 43k miles. I don't know much about the 6.0s and have heard bad things about early ones but did they get better with age. What is fuel mileage. What are things to look for. Do they inject fuel into exhaust like the 6.4s. And what tunes or performance things do I need to look at. I just pull a 10k pd camp trailer. But like the extra power. All the help or info would be great............ Thanks Chris
Plan on spending an extra 5k on top of whatever you purchase it for to instal...
ARP studs, black onyx head gaskets, EGR delete, upgrade turbo drain pipe, upgrade stc fitting, 6.4 banjo bolts, and upgraded FPR spring. Sounds like a lot but it is not to badd if you shop around through the ORG and on eBay.... I love my 6.0 and wouldn't trade her for the world. Good combination of speed and power. AND lets not forget responsive! Unlike the older PSD the 6.0 will pin you to the seat or if you are cruising along at 60 and now what to pass someone at 80.... She will have all you want.. ..
Have the dealer run an OASIS report to see if it's had a lot of problems. I would for sure do an egr delete right off the bat, then do a coolant flush and install a coolant filter.
Looks like we are in almost the same boat but i still have my 97 it has 123k on it, i got it new still runs great but my 06 will out pull it 2 to 1 but M/T i think my 97 is quicker. If you do the right things get a good set of gauges like the Edge Insight to check temps the ECT-EOT are important over 15* your coolers are getting plugged then you will need new oil cooler and EGR cooler then you should do ARP studs, coolant filter to remove the casting sand and other junk in the coolant, fuel pressure gauge under 45lbs at WOT kills injectors and over 70lbs may blow o-rings, and if you plan on keeping it install a oil by-pass system the stock filter cleans to 20 microns and the by-pass cleans to 2 microns and the injectors like clean Syn oil and use only Ford filters, then do a coolant flush to remove the Ford Gold cxxp coolant and install ELC coolant. Get an Oasis Report to see if it is a problem child this will tell you everything that has been repaired by Ford, run centane boost in the fuel and after it warms up about once a week drive it like you stole it to keep the turbo and EGR valve clean. Mine runs great pulling my 14k 5er mpg 8-9 pulling 14-17 solo sometime as high as 19 on a good day. 2 stroker |
WOW! That sounds like alot. I had my 7.3 for 6-7 yrs and never did a thing to it. Could you get a 6.0 and it be ok to drive for awhile and do some pulling without doing all this, or is it a must do ASAP? The trucks Ive been looking at have been in the 27-30k range and I don't have much letf to do alot of upgrades at first.
I have 168k on my 6.0 original egr cooler,head gaskets... I do not believe you need to spend 5 k on it. It has been several time sthat a 6.0 is as good to you as you are to it, If you maitain it and keep fuel,coolant and oil clean you will be fine. I would however delete egr asap, and exhaust, thats it.
The first thing you need to do is get rid of the Ford G-05 coolant and replace it with a Cat EC-1 rated ELC. Many of the problem you hear about are a result of this coolant. The links in my signature will give you more information. It is not necessary to do all that stuff right away and if you get the Ford coolant out of there you may never need to do studs or head gaskets.
For more power SCT with custom tunes is the only way to go with 6.0. Read up. Ther is a lot of information on this site. And don't be afraid to ask questions. |
I guess im not sure about the oil cooler. What is or where is the oil cooler. Also how hard is it to do the work your self. I have done just about everything on my 7.3, but its never been anything major. Glow plugs. water pump, lift pump. Im no great mechanic but I try to do as much as I can.
