3:55 Ration = Fuel Savings? - Ford Powerstroke Diesel Forum
Old 01-08-2011, 02:46 PM
I have a 2003 F250 6.0 with 3.73 gears. I use to do a bunch of towing but now I might use the trailer 3 times a year so the rest of the time the truck is my daily driver.
Would swapping to 3:55/3:54 gears help increase the MPG?
Old 01-08-2011, 03:10 PM
Depends on the use. That is too much strain at the lower rpms.
Search on google and you will find many posts on what to do for mpg.
tuning is a big part.
Is your truck 100% stock?
Old 01-08-2011, 03:53 PM
NOT a Democrat
I dont think it will be enough of a change to make it worth while. Also, I agree, start with your tuning. When I was racing a lot, I was going back and forth from 3:55, 3:73, to 4:10s for some different outcomes at the finish line and different tires.
I am thinking for your street driving and going after some more milage, it wouldnt be worth doing 3:55s. If you are a 4X4, it is really not worth it in my mind. What size tires are you running? Just changing that might help out a lot as well! On my Mustang, I was traping at the same speed with 3:73s and a 28" slick as I was with 3:55s and a 26" slick.
Just my thoughts!
Old 01-08-2011, 04:50 PM
Stick with you 3.73 gears. And buying 2 sets of gears is very pricey.
What was better with the gears?
Old 01-08-2011, 04:53 PM
NOT a Democrat
Results were about the same with 3:55s and a 26" tire vs the 3:73s and 28". I ran out of gear with the 3:73s and the 26" tire. The 4:10s are now in it and no spray. I can run a 26" tire and just hit red line at the line. 100% NA and slower now!
Old 01-08-2011, 05:02 PM
Thanks for the comments. Mine is a 4x4. I've got an Edge programmer with the in cab monitor. Other than that I have installed a Air Raid intake to get more air into the motor. I'm one size over the stock tire size.
Upgrade I want to do next is a 4" exhaust system.
Old 01-08-2011, 05:11 PM
I saw on Trucks that changing to manual hubs and swapping the cooling fan to an electric fan both do wonders to reduce MPG.
