checking new turbo ? - Ford Powerstroke Diesel Forum
Old 01-08-2011, 08:42 AM
so i got my new turbo in and gave it a week before i got on it . i notice now there is definitely less lag but it doesnt seem to take off as quick . maybe i'm just not used to not having so much lag . before the new turbo if i punched it gettting on the highway i would have a pause the BAM ! the truck would go insane . i guess what i am asking is if this is normal .
old turbo
Old 01-08-2011, 09:29 AM
Your post is confusing, do you have less or more lag? Did you go back with a stock turbo?
Old 01-08-2011, 09:37 AM
sorry about that . i went to a stock repalcement . the truck has less leg , but for some reason doesnt seem to get to speed as fast as before .
Old 01-08-2011, 09:39 AM
You may have a leak.
Old 01-08-2011, 09:43 AM
thats what i thought , i checked around turbo and where exhaust connects and couldnt see anything . you think i could tell if i did a datalog with my SCT and compare it to the one i did with the old turbo ? if so would it show lower boost if there is a leak ?
Old 01-08-2011, 09:54 AM
the turbo was a reman
Old 01-08-2011, 01:41 PM
what are your boost levels ?? same as before ??
Old 01-08-2011, 02:38 PM
Check your intake tubes. Are there any oil leaks for the trubo?
Old 01-08-2011, 03:38 PM
boost levels are pretty close to the same and there are no oil leaks anywhere . i think its just me . i did another datalog with the new turbo and the boost levels at 2400 rpm were almost identical . i dont know if that actually tells you anything .
