Turbo sitting full of oil? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-05-2011, 01:20 PM Thread Starter
Quoted: 5 Post(s)
Pulling an engine in a 03 6.0 that i bought to flip and when i pulled the passenger side intercooler tube off and looked into the turbo it is sitting full of oil. Just wondering what would cause this and if i should suspect the turbo as bad as well as the ending since the replacement engine i have is without the turbo. Thanks
DENALI is offline
post #2 of 12 Old 01-05-2011, 01:29 PM
ab2625's Avatar
Was there just a light coating of oil? If so it could just be from the CCV.
04 F250 6.0 CCSB Lariat
ARPs, Insight CS, SCT gearhead & Quicktricks, RCD EGR Delete, MBRP 4" straight, Airaid Intake, upgraded banjo bolts, Blue spring, Harpooned tank, Dfuser Coolant filter, CCV filter, High Idle, ELC, 8" lift & 38's, Custom Ladder bars, RedHead steering gear, DDM HIDs heads & fogs, 20% tint, 08 console, 08 rear bumper, 08 Mirrors, 08 trans pan & filter & GOGO Solonoid
ab2625 is offline
post #3 of 12 Old 01-05-2011, 01:32 PM Thread Starter
Quoted: 5 Post(s)
No its standing oil as in a lot. Turbo isnt off yet but i bet by looking if its poured off there would be a couple cups worth at least. I bought the truck as having a bad engine, 2 cylinders were supposed to be dead on it. I tried to start it but it wouldnt even crank over so i wasnt concerned with doing anything to it since my plans were to replace the engine anyhow. But i was planning to use the turbo off of the current engine on the replacement.
DENALI is offline
post #4 of 12 Old 01-05-2011, 04:02 PM
superjet701k's Avatar
rebuild the turbo apex turbo in ca will sell you all the parts i called around and kept coming up with noone to sell me parts esp on the eastcoast where i live pm me ill give you the number. there real easy to take apart if your where wondering. youll need to miC up the bushings ID,OD,LENGTH and the bearing housing ID. 120$ KIT
OIF 1 ARMY VETERAN
8' fisher MM2 plow
Dieselsite coolant filter
fuel presure reg spring
air box mod
6.4 banjo's
RAE batterys
CCV mod
2010 side steps
turbo back 4" no kitty
superjet701k is offline
post #5 of 12 Old 01-05-2011, 04:19 PM
dieselkane's Avatar
Have you tried turning over the engine by hand? Just curious.
dieselkane is offline
post #6 of 12 Old 01-05-2011, 05:25 PM Thread Starter
Quoted: 5 Post(s)
Nope it wont turn over. Not sure what the deal is with it. Previous owner parked it where i picked it up about 4 months prior to my buying it and he never restarted it. It has 118k on it. He said that Ford had told him that 2 cylinders were way low on compression and it was smoking really bad so he just parked it and decided to sell it. So somehow from the time he parked it till now the turbo filled with oil somehow. I will know more tomorrow when the turbo is off. I am wondering if the crankcase might be overfilled or something, will check that as well.
DENALI is offline
post #7 of 12 Old 01-06-2011, 01:30 PM Thread Starter
Quoted: 5 Post(s)
Just a little update, we drained 14 gallons out of the oil pan today. Not sure how that much diesel got in there but that was evidently what caused the engine to go bad in the first place. Any ideas why there would be so much in the pan? THanks
DENALI is offline
post #8 of 12 Old 01-06-2011, 01:47 PM
14 gallons? Gallons? Not quarts but gallons?
Diesel fuel?
Wow.
There is no telling. It could be a multitude of things but I have no explanation other than someone being very stupid.
obsidian is offline
post #9 of 12 Old 01-06-2011, 02:53 PM
Galaxie's Avatar
Yea 14 gallons is really hard to get in there. Sounds like vandalism.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #10 of 12 Old 01-06-2011, 02:59 PM Thread Starter
Quoted: 5 Post(s)
Diesel fuel?
Wow.
Yep gallons! Thats why i couldnt get the engine to turn over it was hydrolocked. We let it drain overnight to see if we could get it out of the cylinders so we can turn it over to get the converter bolts out but havnet given it a try yet. If not will have to remove the glow plugs and do it that way. Not sure how in the hell it would get so much fuel in the engine, would really like to know though.
DENALI is offline
