Battery Light Flickers - Ford Powerstroke Diesel Forum
Old 01-04-2011, 06:17 PM
The battery light flickers when at low idle. No performance problems and easy starts. Any suggestions?
Old 01-04-2011, 06:35 PM
I have had 2 alternators go bad on my 01 7.3L, both times the battery light did the same thing you describe....It would flicker for a while, sometimes stay on for a longer amount of time, but the truck would start and run fine until finally it just went completely bad.... Good Luck
Old 01-04-2011, 07:18 PM
Feedback Score: 9 reviews
Mine does the same thing. It ended up being a bad plug to the alternator, but my diesel tech hasn't found an old engine harness to splice me a new one for it.
Old 01-04-2011, 07:49 PM
yes its going to be something with your alternator. check the connections if that doesnt work dont wait till the light stays on get it tested. i just had to replace mine.
Old 01-05-2011, 10:27 AM
NOT a Democrat
This has happend to me with a 3G on a Mustang. It was the regulator brushes going. They were almost totaly worn out. It did that exact thing you discribed.
So.
1. Check connections
2. If connections are good, get an alt!
If you dont want to buy a new one, take yours apart, you might see somthing simple like what I stated. Not sure, I have never had one of ours apart. Just smaller ones.
Old 01-05-2011, 06:29 PM
Checked voltage on batteries with the truck not running and it ts ok. Checked voltage with the truck running and it is not consistent. Now to find out if it is the alternator or wiring. With 180k miles on the clock. Probably the alternator.
Old 01-07-2011, 09:20 PM
Don't give up on your alternator yet. Mine was doing the same thing and under acceleration it would come on and go off. I left it idling and started wiggling wires (very technical stuff) on the alternator and heard a click. Light was off and hasn't been back on in 3 months. Let us know what you find out!
Old 01-07-2011, 09:38 PM
mine was flickering while i was driving yesterday, it was the plug on the alternator...had been laying on it while pulling the turbo...and has mentioned above..."wiggled the wires and heard a pop" hasn't been on yet
Old 01-09-2011, 07:07 PM
Had mine checked and it was bad. Got it rebuilt for $95. Got it on and all I can say is the person that said 7 min to change alternator is FOS.
Old 01-09-2011, 07:09 PM
Send a message via AIM to troid123
99% sure your alternator is shot, replace it!!!
