Are Mag-Hytec Products really worth the money?
I've been wondering for a while if the Mag-hytec tranny pans and rear diff covers really do what they say they do and if they're worth the money. I've looked into them for a while now, and have really been looking at the tranny pan in particular, just because I want the transmission to run as smooth and cool as possible, when I'm really running my truck hard. My tranny on my last truck $h!T the bed twice in 2 months the first was a complete overhaul and upgrade, the second, it wasn't put back together properly and completely seized up. That tranny was crappy in the first place and I was trying to put to much power through it, and it didn't have proper cooling. I want to try to avoid something like that happening w/ this truck, so I ask all those that have the products, are they worth it?
Thanks. -BG06. |
IMO i would just add an auxilliary tranny cooler. the bigger pans just add more fluid to cool when it does get hot. with an aux cooler it should do alot better.That is the route i am gonna take
yeah i found a place that u can get an Aux trans cooler for 179 dollars. comes with electric fan and can be operated by temp or manually. Orange County Diesel CALL 888-OC DIESEL
I thought my 250 came w/ an AUX tranny cooler with the towing package?
-BG06. |
it does but you can get a secondary tranny cooler...... i would suggest that over the bigger tranny pan.....
Brian, from BTS has a good point about higher volume trans pan. The fact is it will indeed take longer to reach opertaing temp, but it also takes much longer to run that fluid through the cooler. So they really may do worse than the factory pans. There diff covers are awesome though
Is there a site I can go to to see a picture of these aux coolers? The Orange Cty site doesn't display pics. Also are their any site sponsors that will give a discounted price?
Thanks. -BG06. |
Discount power parts had a good deal on a transtar tranny cooler a while back. Stump did a write up on the install
Transtar Tranny Oil Cooler Install |
Should I get one with a fan like SgtStroked7.3 said, or just go w/ a tube style cooler? What are the differences?
-BG06. |
the fan one will usually come on at 170 degrees... thats the one ill be putting in my truck...
