6.0 excess boost - Ford Powerstroke Diesel Forum
Old 01-04-2011, 03:14 PM
6.0 excess boost
To the mechanics,
How does a VGT lose excess boost without a wastegate or blow off valve. I always thought mine had a wastegate because when I quickly let off pedal after floored, I hear a loud flapping noise.
Old 01-04-2011, 03:20 PM
Originally Posted by richy View Post
To the mechanics,
what year truck makes a differance, but its kinda noramal to hear a burb or two its in the intake esp on 03 an 04
Old 01-04-2011, 03:25 PM
Its an 05 bone stock. I actually pulled down a garage with it the other month. I was half throttle not going anywhere. I let off real fast and it made the sound exactly like a blow off valve would. My sister used to have a pimped out ricer that made the same exact sound when she let off. Mine does it all the time but that time was particularly loud.
Old 01-04-2011, 05:23 PM
Old 01-04-2011, 05:46 PM
It's commonly called a "turbo-fart", and that noise is the air going back out of the turbo and then through the air filter. The 6.0L has no waste gate.
Old 01-04-2011, 05:54 PM
Send a message via AIM to FastFocus
that sound you heard is nothing like a blow off valve sounds. What you're hearing is compressor surge. It happens when you have pressurized air being pulled in via the turbo under boost, when you abruptly let off the throttle there is excess boost pressure that has no where to go, so it hits the wheel on the turbo which causes it to spin in reverse while air is being pulled and pushed in at the same time.
if your sister's ricer made that sound then her blow off valve was not working correctly and she was causing damage to her turbo.
The VGT acts as both a wastegate and a B.O.V. as it is able to adjust itself to allow airflow. Sometimes however it will not act quick enough and you will hear the compressor surge, or "turbo fart" that is commonly used among powerstroke owners.
