ECT and EOT Code - Ford Powerstroke Diesel Forum
Old 01-03-2011, 02:48 PM
ECT and EOT Code
Question,
Does anybody know if a code would be thrown when there is a difference between EOT and ECT?? And if so how much differential. 05 f350 102K
Old 01-03-2011, 02:51 PM
Send a message via AIM to troid123
Originally Posted by richy View Post
Question,
With the latest flash from ford, YES it will throw a CEL It has to be a 15 degree difference if I am not mistaken..
Old 01-03-2011, 02:52 PM
Nice thanks.
I know the difference should not exceed 15 degrees for extended periods of time but not sure if it would cause a code.
Old 01-03-2011, 02:53 PM
Thanks blackshadow. I am planning an EGR cooler delete in spring. How did that sinister work out for you
Old 01-03-2011, 03:07 PM
I did a lot of research and I think Sinister has the best quality. It worked out quite nice for me. I would highly recommend it!!!
Old 01-03-2011, 03:09 PM
Cool, good to know. Nice truck by the way, its exactly mine without the utility body
Old 01-03-2011, 03:19 PM
That code is not thrown for all model years - only 05 and up I believe.
Old 01-03-2011, 03:57 PM
i have 30-50 deg differance yfor over a year now before and after a new egr and oil cooler installed and still the same spread. tonight did multi flushes again and put in a new tsat cause. i was 185 ect, with new tsat its 180 deg ect i fing give up this junker is going back to the retards at ford. im buying a f350 gasser and a supercharger. ps no code for the big spread 2006 powerchoke
Old 01-03-2011, 03:58 PM
Feedback Score: 3 reviews
Your also gonna need to replace the oil cooler, that is why your getting the code. The oil cooler is blocked up.
