Just changed my oil, just want to make sure.... - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-01-2011, 11:56 AM Thread Starter
twotonevert's Avatar
Quoted: 3 Post(s)
My oil temps have come up over the last few days and I was due for a change anyway. Just changed it with Rotella T triple 10/30. With filter change it should hold 15 quarts right? My level is too high on the dip stick and and I dont want to blow a seal. I know it holds 15 quarts, but why not 16?
2013 F350, Adobe
twotonevert is offline
post #2 of 10 Old 01-01-2011, 01:01 PM
Quoted: 23 Post(s)
Any diesel engine can allow fuel to get into the oil. You should keep your oil level between min and max to be able to know what is going on w/ the engine. 14 quarts puts my level just below the max line, so I go w/ 14 instead of what the book says - many people do. Too much oil can also cause foaming, which will create issues w/ injectors.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #3 of 10 Old 01-01-2011, 01:04 PM
Isakson's Avatar
my 7.3 takes 14 qts
1996 F 350 7.3L 4x4 226,000 Miles on the Clock and Still Tickin!
Edge Evolution: Extreme
SUPERDUTY SEATS
Kobalt Tool Box
Isakson is offline
post #4 of 10 Old 01-01-2011, 01:18 PM Thread Starter
Quoted: 3 Post(s)
Crap, so I have a quart too much?
2013 F350, Adobe
post #5 of 10 Old 01-01-2011, 01:36 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Kind a looks like you do. I wouldn't want to run it over filled. For the reasons Bismic mentioned.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #6 of 10 Old 01-01-2011, 03:23 PM
A little over full won't kill you. But I am talking ONLY a little. 1qt... well I would drain some of it. I personally prefer mine between the low and high, like right in the middle.
obsidian is offline
post #7 of 10 Old 01-01-2011, 06:33 PM Thread Starter
Quoted: 3 Post(s)
Thanks guys, I will drain about a quart or so in the morning. I appreciate the advice.
2013 F350, Adobe
post #8 of 10 Old 01-01-2011, 08:15 PM
Quoted: 27 Post(s)
1 qt will make no difference. I alway's use 15 qts. If you overfill a 1.5L Toyota engine by a qt. or more I would worry but not the 6.0. I remember reading one of the tech's on here talking about how he was troubleshooting a sluggish running 6.0 and he drained the oil to find 30 qt's coming out of the pan. Much more excessive than your 1 qt but I'm just showing you that you aren't going to have any problems.
Banshee365 is offline
post #9 of 10 Old 01-01-2011, 08:25 PM
Quoted: 23 Post(s)
How will you ever know if you have a lot of fuel in your tank - say 5 quarts or even 15 quarts (which would be a problem) - if your typical fill level is past the max mark on the dipstick? Clearly the Tech in your example had to drain the tank to find out.
Anyway, I agree about 1 quart not making a difference, just emphasizing how you can stay on top of your vehicles operating conditions. Oh - and 2 quarts underfill is not really an issue either.
Mark
bismic is offline
post #10 of 10 Old 01-02-2011, 05:33 AM Thread Starter
Quoted: 3 Post(s)
Thank again guys. I drained exactly 15 quarts out of it, full capacity on the catch pan. It just weirded me out that capacity was max on the dipstick. Good thing about the Edge CTS, it keeps me on top of the engine. After my oil change we had some errands to run last night and my oil and coolant levels were right back to within 1 to 2 degrees of each other. Now I just need to change my coolant and I will be very happy.
2013 F350, Adobe
