Differential Covers / Gaskets - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-31-2010, 11:07 AM Thread Starter
Quoted: 100 Post(s)
Have a 2004 F350 4x4 and am contemplating changing the differential fluids....just because the truck is worked hard hauling items and figured an ounce of prevention may be worth something.
Do these differential covers use a gasket or is silicone sealant just applied and the surfaces mated to make/form the gasket?
jd4010 is offline
post #2 of 6 Old 12-31-2010, 01:11 PM
Jayson41's Avatar
Black RTV, amsoil.com will give you amount of fluids needed.
Bullet Proof Diesel Semi Bullet Proof Kit - Diesel Site Coolant Filter - Banks Monster 4" Exhaust - High Idel Switch - 2.5 inch Leveling Kit - 295/70/18 Nitto Trail Grappler M/T's - Amsoil
Jayson41 is offline
post #3 of 6 Old 12-31-2010, 02:34 PM
smokersteve's Avatar
Quoted: 20 Post(s)
amsoil will tell you how much on their web site.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #4 of 6 Old 12-31-2010, 02:45 PM
artsamm's Avatar
If Amsoil is giving fluid away, I better get some before they change their mind!
artsamm is offline
post #5 of 6 Old 12-31-2010, 05:07 PM
bfrank81's Avatar
This is the article that I followed when I did this on my Jeep. It's pretty easy to do. Jeep Axle Differential Fluid Change Service I bought a pump from Harbor Freight for a few bucks and that made it easy.
The only tricky part is getting the RTV just right so you don't have any leaks. I screwed up the first time and didn't have enough on the bottom and ended up with a small leak. No biggie just had to redo it.
Brian
bfrank81 is offline
post #6 of 6 Old 12-31-2010, 05:13 PM
Lubbockguy1979's Avatar
Quoted: 4 Post(s)
Send a message via Yahoo to Lubbockguy1979
Pretty easy. Put a bead of rtv I use the black stuff and lay a bead also going aroud the bolts. Typically will let it set up for a hour or two then toss in the fluid. Haven't done it on this truck but typically fill the fluid to the top of the fill hole.
Randy
2006 f250 4x4
crewcab shortbed
lariat auto
Some tuning, gauges and other assorted non factory dodads
Lubbockguy1979 is offline
