crankcase vent mod - Ford Powerstroke Diesel Forum
Old 12-31-2010, 01:40 AM
crankcase vent mod
Here is what I did to stop dirty crankcase fumes from getting sucked into the intake. Ford has the vent routed back to the intake on the left valve cover (genius!!). Same as the 7.3l for the most part. This is what causes all the oil that builds up around your intercooler tubes and the mod will eliminate that.
I rerouted the vent to exit below the frame rail. It is a 1" hose and it uses a 1" splice. Be careful where you route the vent so it is not on anything hot or rubbing anything the wrong way. There is only one direction the vent can face or it will hit intake tube.
I pull the 90* plastic fitting out of the intake pipe and put a PVC threaded pipe plug in it and secured it with a hose clamp. The plug is approximate 1.03" when measured on the OD of the threads. I don't remember what the actual plug size is by name. Anything bigger won't fit and this is the only thing close I could find to fit. I painted it black with a marker so it would not stand out. Then reassemble.
I also do this on the 7.3l trucks we work on, except i flip the crankcase vent 180* (remove two screws and rotate) so the vent is on the back half of the valve cover and that gets it out of the way. The intake gets a 3/4" vacuum cap on it. You can't flip the 6.0 because the FICM is in the way.
Old 12-31-2010, 06:46 AM
I noticed you routed the hose straight down to the frame rail. Others who have done this mod say you need a rise in the hose before it drops down, otherwise it'll turn into an oil fountain. Are you having issues with oil just pouring out of the hose?
I "dumped" mine as well, but made sure to put the rise in the hose. Now it sticks out like a sore thumb in the engine bay. I would much rather run it straight down to conceal it.
Old 12-31-2010, 07:19 AM
This is the first 6.0l I have worked on so I hope that is not the case. I have been doing this on the 7.3 motors for a while without a rise and have not had any troubles. Most of the semis I work on don't have a rise either (even the detroits, which have a ton of crankcase pressure). I think as long as you have your vent coming out of the highest point of the motor, you should be okay. I have seen a few trucks with catch cans to collect the oil. There will probably be some drooling at the end of the tube.
Old 02-07-2013, 04:12 PM
Do you get a sour like smell in the cab with the Vent hose positioned like it is. I have an AFE with the Vent hose positioned down the side of the engine and can smell the vent fumes sometimes in the cab when Idling.
