Quick ? about oil filter patent numbers - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-30-2010, 01:07 PM Thread Starter
RedEagle's Avatar
Let me start off by saying I WILL ONLY USE Motorcraft and/or Racor filters in my rig. I came across a filter at O'Reilly's, it is their Microguard store brand and it has the same identical patent numbers on it that the Motorcraft filter does.
So here's my question......
Would having the same patent numbers on the filter indicate that it was a "repackaged" Racor?
Motocraft @ Wallyworld = $20.00
Microguard @ O'Reilly's = $13.49
Also......the instruction sheet from the O'Reilly's is also identical to the Motorcraft instructions, even down to the "Instruction Part Number 21743 Rev D" printed at the bottom.
Vic
'06 F250 SD, 6.0 PSD, CC, SB
DieselSite coolant filter
high idle mod
ScanGauge II w/Blendmount
Glow Shift FP gauge
Fumoto drain valve
HFCM water drain plug upgrade
Blue spring
Inverter
RedEagle is offline
post #2 of 6 Old 12-30-2010, 01:08 PM
DesertSmoker's Avatar
For Sale--2003 F-250 CC 4x4 SB 6.0
Custom 03 Turbo, WPE Intake,
HD 97 Fan Clutch, MBRP Y Pipe,
Scangauge II Rancho 9000XL,
BFG 285/75 R16, Galaxy 94HP
DesertSmoker is offline
post #3 of 6 Old 12-30-2010, 01:40 PM
smokersteve's Avatar
Quoted: 20 Post(s)
Same here! I would really like to use it. Same exact pattents. looks exactly the same. I asked the clerk who makes microguard and he said it was MG's own filter. So im still not sure.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #4 of 6 Old 12-30-2010, 01:52 PM
superjet701k's Avatar
run it it will be fine just change it after 3500 miles
OIF 1 ARMY VETERAN
8' fisher MM2 plow
Dieselsite coolant filter
fuel presure reg spring
air box mod
6.4 banjo's
RAE batterys
CCV mod
2010 side steps
turbo back 4" no kitty
superjet701k is offline
post #5 of 6 Old 12-30-2010, 02:33 PM
If it has the same patent #'s its the same filter, repackaged.
There have been many different threads on this very subject concerning not only microguard, but also fram.
roadrunner is offline
post #6 of 6 Old 12-30-2010, 03:12 PM
there are not many filter manufactures left. most make all the filters with different labels etc. same with some batteries just a different sticker. have o reilys get you filtration specs and compare them to motorcraft.
19558077 is offline
