AE Results and now Questions
Ok so I got the AE tool and did some test on the truck and also got some codes. Test done with coolant at 141 F.
BUZZ Test - How many buzzes should you hear? It says you should hear all of them, then each injector 1-8. I heard three. ICP was aroung 580 ish on idle at 750 rpm. Ran a power balance and didnt really see much. every now and then seemed like I had a low spot right at #1 injector. less than 25 rpm deviation. Coolant and oil temp were 165/160 All the codes I got KOEO TEST U0306 Software incompaptible with FICM DTC U1900 Can Communication Bus Fault B2373 #1 LED circuit short to battery C1710 Right Rear Center Sensor Fault C1709 Right Rear Center Sensor Failure B1359 Ignition Run/ACC ciruit Failure B1483 Brake pedal input circuit failure P1876 Transfer case 2-wheel drive soleniod circuit failure B1352 Ignition Key-in Circuit failure B1360 Igniton Run/Acc Circuit open Anyone know what these codes could be or how to fix? |
I've had the P1876 Transfer Case 2-Wheel Drive code for 2 years now. Haven't been able to figure out what it is but have felt no ill effects from it.
Just a question on the two ignition codes: Have you done the "dinger mod"? It's possible maybe that having pulled the ground wire your truck is considering that an error maybe?
