turbo oil return line oring and gasket ? - Ford Powerstroke Diesel Forum
Old 12-29-2010, 06:30 AM
so i got a new turbo and i'm not sure what oring is suppose to come with it but i didnt get one . do i need a o ring and a paper gasket ? thanx
Old 12-29-2010, 06:33 AM
also any install tips would be appreciated as well .
Old 12-29-2010, 08:59 AM
Slacker
Feedback Score: 4 reviews
There is a kit that includes both of those components as well as new hold-down bolts for the turbo. I don't recall the part number off hand, but you may be able to reuse your old ones if you must get it back together right away. Otherwise, I would get them from the parts department.
Here's a LINK to another thread where M-Chan describes the exact process.
Old 12-29-2010, 11:58 AM
What turbo did you wind up gettin?
Here's the part number
3C3Z-9T514-AD Hardware kit
I believe it only comes with the drain back O-rings but it does have the feed line gasket.
Use Anti-seize on yer bolts too so you or the next guy don't have to fight them if the turbo ever comes out again.
