MKM Coolant bypass kit. - Ford Powerstroke Diesel Forum
Old 12-28-2010, 10:14 PM
I really like the looks of this kit but don't know much about it. I wanted to see if anyone has any experience with this kit before I order it. I know most people run the Dieselsite kit but I think this will really go good with the NUC oil bypass kit when I order it. I have included a link for the MKM/Sinister collant bypass below. All input will be greatly appreciated.
Thanks
Image Gallery
Old 12-28-2010, 11:41 PM
I ordered one 2 weeks ago. When i install it (another week or so) i will post my results. I like the look and location of it
What is the NUC oil bypass kit? Is it cheaper than $500!!!
Old 12-28-2010, 11:49 PM
NUC motorsports is the seller but the kit is made by Amsoil. They offer two different kits. I have included links below.
FORD 6.0 POWERSTROKE BYPASS OIL FILTER KIT XMAS SPECIAL - eBay (item 260701296172 end time Dec-30-10 21:12:54 PST)
FORD 6.0 POWERSTROKE BYPASS OIL FILTRATION FILTER KIT 1 - eBay (item 260681475895 end time Jan-19-11 18:59:55 PST)
Hope this helps
Old 12-29-2010, 12:32 AM
Just so i understand 100%
You take out your stock filter entirely. Put this new cap on. Which routs the oil to the AMSoil filter and then it drops it down the filler neck?
Does the oil still go through the oil cooler?
Does that oil filter cap replacement have some piece that i do not see fit down over the inlet to the stock filter?
Thx,
M
Old 12-29-2010, 12:34 AM
It must some how block the normal return of oil to the pan.
Okay i went to NUC Motorsports Web site and read the installation instructions.
Where do i get a new flow through filter? The reason i ask is that my WIX filters i have bought have a cap on them? I guess i need to buy some stock Motorcraft filters
i bought a system on ebay, weak moment, but my truck will like it hehe.
M
Old 12-29-2010, 03:47 AM
I just got this for Christmas! I will be installing it once I flush my system. It seems of a good quality piece and it has some good weight to it.
Old 12-29-2010, 03:55 AM
Thanks
Image Gallery
As far as the coolant kit, mine (ordered from MKM) came with all Dieselsite packaging, brochures, etc...
Old 12-29-2010, 04:27 AM
1. You take out your stock filter entirely.
2. Put this new cap on.
3. Does the oil still go through the oil cooler?
4. Does that oil filter cap replacement have some piece that i do not see fit down over the inlet to the stock filter?
Thx,
M
1.No, you will still use a OEM filter system (with the new type cap)
2. The new cap is for mounting of a fitting which will take some oil and send to the bypass filter only.
3.Yes
4. new cap works the same with the exception of the fitting at the top which routes oil to the Amsoil bypass filter.
Don't get hung up on the new oil filter cap, it just holds a fitting. Theoretically you could drill and tap a hole in your old cap and put a fitting in.
Oil filler cap also just holds a fitting to route the bypass filtered oil back to the pan.
Old 12-29-2010, 04:28 AM
So, is this essentially a dieselsite kit?
Old 12-29-2010, 04:32 AM
Ford 6.0, 6.4 and 7.3 Oil Bypass Systems and Billet Aluminum Filter Caps
Then why does it talk about the Delux kit with flow through filter?
Thx,
M
