P0470 code, Were is that sensor? - Ford Powerstroke Diesel Forum
Old 12-28-2010, 06:31 AM
After a rough cold start p0470 code popped up. Were is that backpressure sensor located and how to fix? (already did a search no luck)
Old 12-28-2010, 08:00 AM
huj huj is offline
Feedback Score: 3 reviews
right by the upper rad hose look by ata pipe and air filter
Old 12-28-2010, 08:02 AM
huj huj is offline
also when you remove the sensor startn it up with out of the sensor check for exhaust gas comming out of the tube if nothing comes out its plugged up you need to clean it to avoid other problems cordless drill with aircraft cable does the magic
Old 12-28-2010, 10:06 AM
Ahh crap. I unplugged a sensor from a tube coming off the exhaust manifold now i have a p0611 fuel pressure code. wtf??
Old 12-28-2010, 11:27 AM
huj huj is offline
0611 ficm code clear fix other codes if comes back = ficm need replacing sorry for bad news
Old 12-28-2010, 02:54 PM
Ok codes were cleared and drove for 2hrs doing arrands, no engine light yet...
