alright lets settle it.
before i start, this is a general diesel thread. with that bein the case i searched and searched for a place for it and couldnt find the proper place. so i figured i would put it here cause i own a 6.0?lol so mods feel free to move it.
moving on. alright guys. im sellin my 6.0 because im tireed of it and want a more reliable diesel. now that doesnt mean im anti ford. i REALLY want a manual 7.3. but thats not the purpose of this thread. what im asking for is information from everbody about each diesel's problem. kind of like a pro and con to help decide which diesel would be the next choice for me and to help everyone understand the complications of each truck whether it be cummins, p stroke, or duramax. so ill start out with what i know Cummins 5.9l -2nd gen- Cons - Killer Dowel Pin - Lift pumps are succeptable to faulting - "53" blocks crack - Death wobble due to easily worn out front ends. Duramax 6.6l 2001-2004- Cons - Injector Harness faulting - Glowplug reflash ( apparently they have extended warranty options to cover injectors ) - IDFS axles break. Powerstroke 7.3l (turbo not idi) Cons havent come across any? lol Cummins 5.9l -6BT- Pro's - Really easy to work on. - Parts are READILY availible. Duramax Pros - Look's pretty? Powertstroke 7.3l pros - you tell me. yall fill in the rest on whatcha know. THIS EXCLUDES 6.0L, 6.4L, AND 6.7L PSTROKES. AND 6.7 CUMMINS AND NEWER DURAMAXES. cause i dont want one. |
very nice and appreciated i forgot to mention that bout the cummins auto 4 speed but have heard the nv manuals are great
With the manuals you'll need a clutch right away if you add any power then there something about a nut on the fifth gear on them trans that falls off or something like that.
The Injector issues on the LB7 duramax should be covered. I believe they are replacing them even if the truck is out of warranty. I did an internship at the Bosch plant in Charleston, SC which is where duramax and cummins injectors are made. We had a total reman line for LB7 injectors. If I remember correctly there was a sleeve inside of the injector that was faulty and kept cracking.
Add PMR's to the cons of the 7.3.
I thought they changed that to 200k but i could be wrong.
7.3 PSD: Upgrade the Cam Position Sensor and the HPOP, and the pros are listed above. Great motor.
