diesel kleen? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-02-2007, 11:31 AM Thread Starter
rednek01's Avatar
Send a message via AIM to rednek01 Send a message via Yahoo to rednek01
diesel kleen?
Hey guys I'm wondering if I messed up. I bought the white bottle of diesel kleen last time I was at walmart. I have 2 questions. First was I supposed to get the grey bottle? If so do I just use the white till its out? Second How much do I use per 10 gallons of diesel? or how much per tank do yall use?
Thanks,
Michael
Michael
Aim/Yahoo: rednekcowboi01
FORD Makes it INTERNATIONAL Shakes it!
2004 CC 6.0 4x4 lariat
MODS:SCT XCAL3, Stacks!, Dfuser coolant filter, 6k HID's, High idle, CCV, Ranch Hand, homefabbed straight pipe, Zoo-dad, 2008 tailights, Isspro Boost gauge, Kenwood head unit, 2 mtx 10's and amp...
FUTURE MODS: Isspro trans EGT and volt gauges, ARP head studs, ???
Parts replaced so far: Oil cooler X2
, EGR cooler, ...no more please!
rednek01 is offline
post #2 of 11 Old 07-02-2007, 11:35 AM
back in the saddle
shu873's Avatar
Thanks,
Michael
The white bottle is just anti gel formula for cold weather, but its still got a cetane booster and lube properties just like the gray bottle. It won't hurt your truck a bit, still much better than nothing... I'd just use it up then get the gray bottle when you need some more. As far as usage, I don't measure mine too well, just a good size splash every time I fill up. If you look at the directions on the container it will tell you how much the jug will treat then you can figure it pretty easy on your own.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #3 of 11 Old 07-02-2007, 11:38 AM
jphelzer's Avatar
For the grey bottle, 8oz is supposed to treat 25 gallons...I get 4 tanks (30 gals per fill-up) out of the 32oz bottle; I've been thinking about trying 1/3 bottle per tank to see if it makes a difference.
2001 F250 Ext Cab LB 4x4
7.3L PSD, 4R100
Stock except for DIY Tymar intake and 4" exhaust
226K miles and counting!
jphelzer is offline
post #4 of 11 Old 07-02-2007, 11:40 AM
cj41foley's Avatar
I've never put anything in my tank, does this cetane boost actually make a difference in performance?
Jason
2006 F250 2wd 6.0 psd, 8.96 1/8th mile with canned SCT tunes, now running Spartan Hybrid Race tune! AFE Stage 2 PRO DRY S, 4" turbo back str8 pipe in front of rear tire, auto, crew cab short bed, ZOO DAD mod, 5% tint over the factory tint.
Track Times!
Reaction---.674
60 ft-------1.892
594 ft------8.370
1/8th ET---8.965
1/8th MPH--75.63
cj41foley is offline
post #5 of 11 Old 07-02-2007, 11:44 AM Thread Starter
rednek01's Avatar
I'm not sure I am going to use it to protect the fuel system and lube it whether it needs it or not with all the bad things I hear about the ULSD I rather be safe than sorry and if I get a lil bit better performance or mileage in doing so then all the more better!
Michael
rednek01 is offline
post #6 of 11 Old 07-02-2007, 11:48 AM
jphelzer's Avatar
That's why I started using it too. Boosting the cetane is supposed to help with performance, but I don't have any dyno #s to compare with.
And, I'm stock except for intake so I might not even notice a difference...
7.3L PSD, 4R100
jphelzer is offline
post #7 of 11 Old 07-02-2007, 11:52 AM
cj41foley's Avatar
well I might put a few gallons of ulsd in mine every few months but thats about it
Jason
Track Times!
Reaction---.674
60 ft-------1.892
594 ft------8.370
1/8th ET---8.965
1/8th MPH--75.63
post #8 of 11 Old 07-02-2007, 11:58 AM Thread Starter
rednek01's Avatar
Oh well thats all we have down here in Houston. My grandmother is a dispatcher and used to be able to tell me where to get LSD but everybody has switched to ULSD so we have no choice!
Michael
rednek01 is offline
post #9 of 11 Old 07-02-2007, 12:04 PM
back in the saddle
shu873's Avatar
I don't believe you'll notice any real difference for the added cetane, but it will help your truck run smoother. I mainly use it for the lubricity and the extra 1 mpg or so I get from using it.
Kurt
ARP's, EGR blocked
Banks technicooler
shu873 is offline
post #10 of 11 Old 07-02-2007, 12:19 PM
thunderinms's Avatar
Send a message via Yahoo to thunderinms
I only use the diesel kleen when I am having mileage issues or going on long trips. With the F-250 I use 8 oz per fill up. With the new Ex PSD I am getting it has a 44 gallon tank, so I will use 1/2 per bottle at fillup. One thing I have seen is you need to be prepared to let the truck urinate as the product is designed to displace water (I think?). On long trips I believe it helps me get another .25 to .50 MPG.
GG
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." - Thomas Jefferson
SI VIS PACEM PARABELLUM
Thunder II aka - THE BEAST
2003 Excursion Limited 4x4
6.0 POWERSTROKE - Stock Tuned
AIRAID Throttle Body Spacer
AIRAID stock box filter
Husky Floor Liners
Firestone Airbags
BIG TEX Grille Guard
Future mods...
4" Turbo Back Exhaust
SCT Livewire with display
thunderinms is offline
