Remove engine without removing cab possible? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-16-2010, 12:11 PM Thread Starter
Quoted: 6 Post(s)
Local guy told me the only way to replace the 6.0 is to remove the cab. I have done an engine swap with a 7.3 no problem so i wanted to ask you guys who are familiar with the 6.0's if this is the case or not as i have no way to remove the cab. Thanks
DENALI is offline
post #2 of 11 Old 12-16-2010, 12:43 PM
War Eagle B's Avatar
Maybe if you removed the front clip and the core support you could take it out the front? But my buddy told me that the core support on an '05 up is welded in, so that might not be much better.
I know on F150 Lightnings they would remove the motor out the bottom, but dropping the whole front suspension seems about as bad as taking off the cab.
2005 F250 FX4 6.0 Powerstroke CC SB; No Cat; High Idle Mod - TOTALED!
2005 F250 Lariat 6.0 Powerstroke CCSB; Scangauge II
War Eagle B is offline
post #3 of 11 Old 12-16-2010, 12:44 PM
Beef52751's Avatar
it is possible to remove the motor without removing the cab. ive personally never done it though, a buddy has and said you basically have to stand the motor on end, but it will come out.
2006 CCSB F-250 King Ranch FX4 6.0
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
Boost, Pyro, and Fuel Pressure Gauges
Beef52751 is offline
post #4 of 11 Old 12-16-2010, 12:47 PM Thread Starter
Quoted: 6 Post(s)
Its a 2003
DENALI is offline
post #5 of 11 Old 12-16-2010, 03:46 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I have seen them pulled out the front with the core support removed. Don't remember what year it was but the core support was a bolt in affair. If the 05 up are not bolted in that'll suck though I do have means to lift the cab.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 11 Old 12-16-2010, 04:46 PM
artsamm's Avatar
pm sent
I have info for pulling engine for a 2004.
Looks like cab on
artsamm is offline
post #7 of 11 Old 12-16-2010, 08:32 PM
We got here in town that only pulls the motor to do the head studs. Pretty big shop round here. Performance Truck And Diesel. He told me it takes a little extra time but all of his customers were complaining we he lifted the cabs about the moaning, creaking and popping you get once you lift the cab. I have not had mine done yet but i have heard others mention these problems after a body off head job.
gb
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #8 of 11 Old 12-16-2010, 09:58 PM
Pitcher's Avatar
The dealer pulled my motor to do the heads without removing anything but the hood. Don't know how but it is possible.
2006 F350 Tow Boss 4x4
Pitcher is offline
post #9 of 11 Old 12-17-2010, 02:41 AM
artsamm's Avatar
Denali: sent you pm
artsamm is offline
post #10 of 11 Old 12-17-2010, 05:31 AM
PGreenSVT's Avatar
My studs were done with the cab off and my truck doesn't make any squeaking creaking noises.
RIP Mitch
the Org crew
