ignition cylinder bad? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-27-2007, 03:47 PM Thread Starter
ifish424's Avatar
anybody ever heard of this problem? when I take the key out of the ignition with the door open, truck still beeps like the key is in the ignition. its just annoying thats all. if i play around with it i can get the beeping to stop, its just annoying. called the dealership and asked what can be done to stop that and they told me that my ignition cylinder is bad....250 bucks, seems like a waste of money to me considering its not actually causing any problem. i guess I could maybe take the fuse out for that alert system and maybe then it would never beep...key in or out. any thoughts???
ifish424 is offline
post #2 of 8 Old 06-27-2007, 05:04 PM
ifish,
yeah, i had this problem on my 05 just after purchase... it would stop if i wiggled it a bit, but it eventually would never stop dinging. mine was under warranty, though, can't give you a price estimate. don't think it would hurt anything...just very annoying. good luck, bud
landgraf
jlandgraf is offline
post #3 of 8 Old 06-27-2007, 05:08 PM
RRonning84
Guest
Posts: n/a
Quoted: Post(s)
I would just disconnect the wire to the beeper, but thats me.
post #4 of 8 Old 06-27-2007, 05:12 PM
LTJDS
LTJDS's Avatar
Exclamation ???
If it is bad it is most likely an issue that by FORDS Standards needs to be replaced comepletly, B-4 you do anything Try to spray some WD-40 in the Slot and maybe the connection issue will make contact. It's worth a try. If not maybe a scrap yard may have one on th CHEAP. Good Luck.
06' F350 FX4, Mickey ATZ's, NOS+, 5" Xhaust, AFE Stg 2,Sneaky Pipe, SCT LWire w/180Hp Tune,CFM+LM Carbon Fiber, 4 AutoMeter Cobalt Gauges, MagHytek Trans & Diffs, FS-2500, LED Lights, T-rex Grill, Zoodad, Clifford Av Guard 5.1 Alarm w/ GPS. AND..2 much 2 List.
WON 1st Detail, & 1st Late Model Daily, @ 07' Truck Nat's, & Won 1st Best Modified @ 07' Ford Power Festival & Won 1st Modified,
& 2nd Highest HP @ SSS 07'
Thanks 2
LTJDS is offline
post #5 of 8 Old 06-27-2007, 05:42 PM Thread Starter
ifish424's Avatar
yea I have already tried spraying WD-40, didn't really help...
ifish424 is offline
post #6 of 8 Old 06-28-2007, 10:14 AM Thread Starter
ifish424's Avatar
anybody know where the dinger is at underneath the dash??? I think i am just going to disconnect the wire to it, but am having trouble finding where that stupid little thing is at...
ifish424 is offline
post #7 of 8 Old 06-28-2007, 11:37 AM Thread Starter
ifish424's Avatar
I just fixed it... the dinger is actually hardwired into the fuse box so you can't just pull the wire to it. there is also no fuse that is only for that, you'd lose other functions as well. To stop that dinging, you have to take the bottom panel of the steering column off, its held on by just 3 screws, then you can depress this little tab and as you turn the key the whole ignition cylinder comes out. once the cylinder is out, you can see the sensor inside there and i just pulled it out. i could have also cut the wire but this way it is reversible without splicing if i ever wanted to hook it back up. But for now it never beeps thank goodness. Its pretty easy if anyone wants to remove it on your own trucks.
ifish424 is offline
post #8 of 8 Old 06-28-2007, 11:54 AM
duct tape & zip ties
bigcountrysg's Avatar
To bad I am a little late on this. I did a write up on this dang dinger a few months back.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
