Edge - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-27-2007, 07:38 AM Thread Starter
Edge
I bought a 2-50 that already had the edge with juice model ejf1000 i found out yesterday that this has been discontinued cause it will eventally cause a surge or stalling problems with the ford updates is what edge says. They want 600 to do a upgrade. Should i leave it untill it acts up of remove and throw away cause there is know why i will buy there product again if they want 600 to upgrade instead of making it right if its been running fine this long when will this happen. Anybody have the ansers cause edge wont email me back
Whitelightning74 is offline
post #2 of 6 Old 06-27-2007, 07:43 AM
back in the saddle
shu873's Avatar
Sounds like crappy customer service to me... Sorry I wish I could help you out, but here's a bump to the top for you. Hopefully somebody reads this that has the same set up you do and can give you some advise. Good luck!
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #3 of 6 Old 06-27-2007, 09:30 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
Make enough noise and most companies will listen to you, try giving Edge a phone call, it is a little more direct
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #4 of 6 Old 06-27-2007, 09:32 AM Thread Starter
thinking about taking it off cause I am going to dealer tommorow for work on it. Is there anything I need to do other than follow the reverse intall instructions.
post #5 of 6 Old 06-27-2007, 09:59 AM
slammedSI's Avatar
Disconect the batteries for a while,
-Bobby Crews- AKA Dr. Cookie Cutter!
2012 Ford F150 Ecoboost
-STOCK-
A 7.3 with an edge should never get into a race. Unless it's with a kid on a bicycle.. and the bike has a flat.
slammedSI is offline
post #6 of 6 Old 06-28-2007, 12:14 AM
DoubleDpsd's Avatar
I had the exact same model on my truck in sig. Didn't notice any issues whatsoever. If you like it I say run it but if you're thinking of getting rid of it then I support that decision even more and look into an xcal2 because the hype is true. it really is just that good.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
