Best way to find an exhaust leak? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 11-29-2010, 09:20 AM Thread Starter
I have an 05 6.0 and it's practically deadly to sit in while idling. The exhaust odor is overpowering to the point that my wife won't even ride in the truck and every person that's sat in it comments about it. I'm sick of it too.
I had the exhaust manifold gaskets replaced last month and it helped a little.
Now, I'm thinking there is a leak someplace else. I asked my mechanic about smoke testing it and he doesn't have the equipment to do it (is it even common?).
Other than feeling around, is there a GOOD way to find a leak? I don't want to be throwing $$ at it chasing a ghost.
Also worth mentioning, the smell of exhaust is brutal outside my truck (in the vicinity) I was parked to an 03 6.0 over the weekend and I couldn't even tell it was a diesel. Is there some engine problem that makes exhaust prominent?
2005 F250 Lariat Crew Cab
Greg Di is offline
post #2 of 20 Old 11-29-2010, 09:25 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 27 Post(s)
Feedback Score: 4 reviews
I'm guessing a cracked up-pipe or Y pipe. They were pretty bad in the 03-04 models, maybe you got one of them on your 05 . If its a Y-pipe, I have a good, used one I'll sell ya
Do you hear any hissing when you're at WOT?
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #3 of 20 Old 11-29-2010, 09:36 AM Thread Starter
I would think my mechanic would have noticed this or looked for it when diagnosing the first time? No? I mean, isn't that stupid obvious?
Greg Di is offline
post #4 of 20 Old 11-29-2010, 09:39 AM
2006PSDSD's Avatar
Quoted: 27 Post(s)
It should be, but the engines are sooo loud when you're laying on top of them, that it may get overlooked
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #5 of 20 Old 11-29-2010, 09:40 AM
2006PSDSD's Avatar
Quoted: 27 Post(s)
Best way I've found to find a leak, is to stick your hand back there when the engine is cooled off, and idleing
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #6 of 20 Old 11-29-2010, 09:55 AM
Snake's Avatar
Quoted: 46 Post(s)
Couple of other ways of troubleshooting:
1) Open the hood and stand in front of the truck while someone else is behind the wheel. Have them punch the gas pedal and look for smoke (likely will come from the top of the motor, especially if its an up-pipe)
2) Look around the flanges for soot. Might have to clean the pipes first, drive it, and then look
Any other symptoms? Are you seeing low boost numbers? Laggy turbo? Higher than normal EGTs?
If you're not seeing these, its possible that your leak is post tubo (at or after your down pipe going to your exhaust)
Snake is offline
post #7 of 20 Old 11-29-2010, 01:22 PM
i have a leak somewere as well and i can hear a hiss sound at idle and driving and when i have my sct turned up smoke comes out from under the hood and stuff you think its y-pipe?
2008 ccsb F250 lariat
SCT tuned by Gearhead Single 371, MPD CCV RCD pushrods ARPS
SOLD!
2003 f250 4x4 crewcab lariat (03 Turbo)
Perfomance:
ARPs, 175/75 Industrial Injection, EGR delete, 5" MBRP,6.4 Banjo Bolts, Coolant filter SCT Innovative Xtreme X, PHP FICM tuner, AirDogII with Sump
2.5" level, 18" monsters with 33/13.00/18 Nitto Terra Grapplers
powerstroke 825 is offline
post #8 of 20 Old 11-29-2010, 01:28 PM
2006PSDSD's Avatar
Quoted: 27 Post(s)
Y pipe or the up pipe would be my guess. Try that test I told the OP, but do it fast before things start heating up
I still have that Y-pipe for sale.....
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #9 of 20 Old 11-29-2010, 03:01 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
I bought some smoke bombs after the 4th of July, and am thinking about using one to test for leaks when the need arises. Maybe put one in my shop vac and blow the smoke into the exhaust and looking for leaks.
Any thoughts on this process?
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #10 of 20 Old 11-29-2010, 03:07 PM
well 2006PSDSD if i do find out i need a y-pipe i will let you know for sure
SOLD!
Perfomance:
