Signs and Symptoms of a Turbo going bad - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-22-2010, 07:58 AM Thread Starter
StrokinKY's Avatar
What are the main signs that your turbo is going bad? Mine sounds weird through my exhaust compared to how it usually sounds. I can't really describe it, but I have no power loss and no oil leaking from my turbo anywhere.
2008 Ford F-250 Lariat Crew Cab 4x4, AFE 5 inch down pipe back exhaust, SCT X3 off road tuner with RCD 450 tune, FLO PRO EGR Delete, S&B cold air intake, Kenwood in dash screen with Bluetooth, Rockford 12" sub, Nitto Dura Grappler 35x12.50 20 inch tires.
StrokinKY is offline
post #2 of 5 Old 11-22-2010, 08:02 AM
NEWT92's Avatar
Sure someone didnt sneak switch a 03 turbo in there when you wasnt looking??
1968 Chevy Impala Custom Coupe ZZ4 350 700R4 trans 3.55 Posi
2003 F250 XLT 2wd. R/C LWB 7.3 Auto Volant Air Intake 4" Turbo Back Exhaust
2008 F250 King Ranch 2wd Crew Cab Short Bed V10 Auto
NEWT92 is offline
post #3 of 5 Old 11-22-2010, 09:29 AM
Slacker
Evil Eye's Avatar
Quoted: 233 Post(s)
Feedback Score: 4 reviews
Usually, surging, oil leakage or significant decrease in boost pressure. A change in sound will usually accompany these symptoms. You should take it in and have it checked out.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 5 Old 11-23-2010, 06:30 AM
1 ) Mine will not spool up sometimes untill I get about 20' away from a stop sign, it just boggs down and belches black smoke until it gets moving
2) Under a load it makes a very loud screeching sound ( almost like a belt slipping ) and has NO Power !
I noticed this about 6 mos ago. ( first sign of going out I found )
3) When I shut the truck off it sounds like a beer can rattling around in the exhaust pipe
YES my Turbo has been out for awhile ! LOL
but a new one should be here in a week or so ...
Rmorgan711 is offline
post #5 of 5 Old 11-23-2010, 06:35 AM
oh yea once I get going down the road it runs fine till I get going up a hill then I notice power rapidly dropping off ....when truck was new '05 It would almost peg the boost gauge at 40 # when I laid into it now the most it will do is about 25# , I figure at 25# it should still run and pull ok ...but no dice , it falls on its face , I don't know exactly how much boost it is really making ?? how accurate are the gauges factory ??
