VC9, RESTORE, DISTILLED WATER, ELC....CHECK - Ford Powerstroke Diesel Forum
post #1 of 30 Old 11-20-2010, 05:18 AM Thread Starter
bailman72's Avatar
alright i've got it all 2 quarts vc9, 1 gallon restore, 18 gallons distilled water (to get started), and rotella elc....and a saturday off so here i go. read up on this quite a bit but just want to verify a few things. mostly the proper order of the flush and the amounts i use....do i go with 2 quarts of vc9 and then flush that out and then use about 3/4 of the gallon of the restore and then flush it out and then go back to distilled to finish up until its all coming out as clear as its going in? also i didn't plan on removing the thermostat, is that a big deal? i was just gonna do some driving around all day to get all the ford demon gold out to get the right stuff in. any other tips anyone has please let me know......thanks!
bailman72 is offline
post #2 of 30 Old 11-20-2010, 05:32 AM
Doing mine today as well. Subscribing to thread.
You can leave the t-stat in, just drive it for 1.5 hours for each of the cleaners. You can use tap water for the "between" flushes but use distilled for the final rinse. Pour in 3.5 gallons of coolant, top off with distilled water and you are good to go. I am replacing the upper and lower hoses though, as long as they are accessable, also changing the t-stat.
Aussiekeeper is offline
post #3 of 30 Old 11-20-2010, 07:49 AM
Trucker's Avatar
Hay bailman72 let us know how it goes when your done. I am looking at doing the flush on Thanksgiving day but I'm using the restore plus instead of the vc9. I was thinking about using the whole gal. of restore but i just seen a post that said don't and now i see your going to use less so maybe it won't be has hard to flush out. I have read were others have had a hard time getting it out.
Phil
Trucker is offline
post #4 of 30 Old 11-20-2010, 08:00 AM
You should use Restore first, it is an alkaline cleaner to remove sludge. Follow that with VC9 or Restore Plus, which are both acidic cleaners for removing rust and scale. Flush with distilled water, then add your coolant. I'll be using Restore and Restore Plus on my dad's '03 next week, that is the order Fleetguard recommends using. The iron cleaner works better after getting the sludge out of the way with Restore.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #5 of 30 Old 11-20-2010, 12:58 PM
asian195's Avatar
Quoted: 2 Post(s)
Not trying to hijack here, but how many gallons will drain out? that way i know how many containers to get..
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #6 of 30 Old 11-20-2010, 01:00 PM
3-4 gallons will drain out each time you flush. You'll need 3.5 gallons of coolant concentrate to get the right concentration of 50/50 and a lot more of distilled water for the flushes.
post #7 of 30 Old 11-20-2010, 01:31 PM
I have read on many threads here to use VC9 first then the Restore.........
So, which is it? I am doing mine here shortly. Waiting for that $80 hose to arrive.
post #8 of 30 Old 11-20-2010, 01:36 PM
Fleetguard says to use Restore, then Restore Plus. Since VC9 is similar to Restore Plus, it should be used last. The acid in Restore Plus and VC9 prep the metal for the new coolant, you don't want to use an alkaline flush after the acid prep.
post #9 of 30 Old 11-20-2010, 02:54 PM
What do we do with all the waste coolant and flushes.
speops38 is offline
post #10 of 30 Old 11-21-2010, 04:51 AM Thread Starter
bailman72's Avatar
ok so here is an update after day one. first let me start by saying this is a must do for all powerstroke owners and it is easy. i chose to leave the t-stat in and so it is more time consuming because of the longer drives but its a nice excuse to cruise around the country in your truck and there is nothing wrong with that. first time i drained it i added the 2 quarts of vc9 and topped off with distilled water and went driving for about an hour and 20 minutes then came home and drained that. i didn't really let the truck cool down but make sure you take the cap off the degas bottle before you drain to relieve the pressure. i then flushed with just distilled water 4 times driving about 15 for 20 minutes between each one with the heat cranked. now it was time for the restore, i added all except for about 1 1/2 inches of the 1 gallon bottle of it because it says its for a 10 gallon system then drove for about 90 minutes. because i was flushing immediatley after my return from driving around i really didn't have to wait for it to get back to operating temp which saved a little time. i have drained the system and flushed with only distilled water since then and i have flush number 10 in my truck right now. i am a little crazy in how i do a job so i may go a little further than most, but i figure this elc is good for atleast 300,000 miles so it is worth doing right. i have used only distilled water the entire time and have been through about 31 gallons but as cheap as it is why not. i have all the flushes back in the 1 gallon jugs and lined up in my driveway and each one gets more clean and clear looking but the restore keeps them a little cloudy so i'm gonna start with some more flushes till its coming out as clear as its going in before i add the elc. thats where i'm at so far.
