06e17 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-23-2007, 06:43 AM Thread Starter
Cobra3824's Avatar
Send a message via AIM to Cobra3824
06e17
So I brought my truck in about a month ago to get an oil leak checked out. While the truck was at Ford they took care of the 06E17 recall for me. Next day I was able to pick my truck up from Ford said everything was all set. Picked the truck up and about 10 miles down the road Check Engine Light came on with P0401 code (insufficient flow) so my buddy cleared it for me and about 5 miles later it came back on. Brought it into Ford the replaced the EGR valve and everything seemed fine. well a little over a week later (lastnight) I was on the highway and felt a loss of power about 2 minutes later Check Engine Light came on. Does this have anything to do with the 06E17 recall they did or do you guys have any other suggestions? Thanks
Cobra3824 is offline
post #2 of 5 Old 06-23-2007, 07:25 AM
Rob
Rob's Avatar
Quoted: 2 Post(s)
i think when i had that happen to my truck, they said it was good to go, then, like you i had the CEL come on mutiple times, they ended up having to replace my EBP sensor and clean the EBP tube along with replacing the EGR valve. AFter that it ran fine.
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #3 of 5 Old 06-23-2007, 07:44 AM Thread Starter
Cobra3824's Avatar
yeah i just talked with the guy over at Ford and Its going back in on tuesday so hopefully they'll get it fixed... its just a pain to see that check engine light on haha... When was your 04 built? Was it built sometime in 03 like mine?
post #4 of 5 Old 06-23-2007, 12:16 PM Thread Starter
Cobra3824's Avatar
Im heading up to Southampton tomorrow(about 2hrs from where I am). I should be fine to drive up there even with my check engine light on reading the P0401 code right?
post #5 of 5 Old 06-23-2007, 12:44 PM
yea...u will be fine if its just a p0401. The latest programming also made them a little pickier about running conditions, so if you had a problem with the EGR developing (or a sticking turbo), the latest programming made the computer pick it up faster than it would have before.
mschn99 is offline
