what makes a good oasis report - Ford Powerstroke Diesel Forum
Old 06-22-2007, 08:29 PM
Just wondering what exactly makes a good oasis report because I just got two of them done and I dont know what what is bad and what is just normal.
Old 06-22-2007, 08:50 PM
Haveing no major work done is always a good sign. small thinks like a reflash and stuff are normal and ok
Old 06-22-2007, 09:10 PM
what about the recals and stuff what all recals did they have
Old 06-22-2007, 09:25 PM
I raelly dont know. There where alot for the early 6.0 (03-04) if they havent been done i wouldnt worrie about it tho.
Old 06-23-2007, 06:30 PM
Post The Oasis Report
Old 06-23-2007, 10:13 PM
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 0 6Y05 000001 * TDRIVE * A96 82 4
AWS Claim Key: 271638 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01988 - * Name: EASTGATE FORD, INC. Ph: 937-4291300 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2004 Doc #:123170A
Cust Comments: DIESEL TEST DRIVE PER FORD
Tech Comments: TEST DROVE VEHICLE AS PART OF PDI
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 4 5C01 050100 F81Z 4635 AB K02 41 11356
AWS Claim Key: 1704320 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2004 Doc #:03005701
Cust Comments: HIGH FREQUENCY VIBRATION UNDER VEHICLE
Tech Comments: FOUND FRONT UNIVERSAL JOINT BINDING REPLACE UNIVERSAL JOINT
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 4 6N06 010201 YC3Z 16C900 AA B66 34 11356
AWS Claim Key: 1704319 Trx Code: E93 Labor Hrs: 0
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2004 Doc #:03005702
Cust Comments: BUG DEFLECTER HANGS LOW ONE SIDE CK.AND ADVISE
Tech Comments: CHECKED AND FOUND DEFLECTER MOLDED DIFFERENT ON ONE SIDE THA N THE OTHER.REPLACED UNDER OVER THE COUNTER WARRANTY.
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 4 5K06 040402 * TWC01 * TB3 42 11356
AWS Claim Key: 1824833 Trx Code: 2 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2004 Doc #:03005705
Cust Comments: VEHICLE SHAKES OVER 50 MILES PER HOUR
Tech Comments: ALL FOUR TIRES TREAD DEPTH 13 36
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 12 6H19 011103 F81Z 2521453 AA B63 33 23896
AWS Claim Key: 4497497 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2005 Doc #:03427001
Cust Comments: DRIVERS DOOR MOULDING AT GLASS DRYROTTING WEATHERSTRIP OVER DOOR ON BODY LOOSE
Tech Comments: REPLACED DRIVERS DOOR MOULDING AT GLASS OUTSIDE
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 14 2G05 031405 * RECAL * D13 42 27141
AWS Claim Key: 5584632 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:24-MAY-2005 Doc #:03528701
Cust Comments: CUST STATES THAT ON COLD STARTS THE ENGINE RUNS ROUGH
Tech Comments: DIAG ENG FOUND NO CODES CHECKED PIDS FOUND NO PROBLEM CHEC KED OASIS AND FOUND SSM 18554 REPORGRAMMED PCM FICM TCM RETESTED OK
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 14 3A15 070100 5C3Z 7G391 BA P69 42 27141
AWS Claim Key: 5584631 Trx Code: S07 Labor Hrs: 12.8
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:24-MAY-2005 Doc #:03528702
Cust Comments: CUSTOMER STATES TRANSMISSION SLIPS ALSO NOT SHIFTING PROPERLY
Tech Comments: ELECTRONIC TRANS DIAG P0766 P2703 P0761 PERFORMED OSC TEST FOUND SOLENOID PRESSURES NOT MATCHING PIDS PINPOINT TEST R&R TRANSMISSION AND FOUND INTERMEDIATE AND DIRECT CLUTCHES BURNTS FOUND SOLENOID BODY BAD HAD METAL & FRICTION MATERIAL CONTAMINATION IN PAN AND IN OIL COOLER FILTER. OVERHAULED TRANSMISSION(MOUNTED ON BENCH) FLUSHED COOLER LINES REPLACED OIL TO AIR COOLER ROAD TESTED REPLACED BO
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 17 2H01 * * * * * * 30849
AWS Claim Key: 6518602 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:08-AUG-2005 Doc #:03652801
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 17 * * * * * * * 30849
AWS Claim Key: 6518601 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:08-AUG-2005 Doc #:03652802
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 17 5K01 040401 1C3Z 1015 BA B65 02 30849
AWS Claim Key: 6518600 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:08-AUG-2005 Doc #:03652803
Cust Comments: CUST STATES THAT HE IS FEELING A VIBRATION WHILE DRIVING
Tech Comments: TEST DROVE AND VERIFIED VIBRATION 52 62 SPEEDS. CHECKED TIRE BALANCE AND FOUND 2 WHEELS BENT NO VISIBLE SIG N OF DAMAGE TO WHEELS REPLACED 2 REAR WHEELS. REDROVE ALL OK
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 19 1H03 030008 4C3Z 9F452 A D42 42 37176
AWS Claim Key: 7327590 Trx Code: S07 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2005 Doc #:03769001
Cust Comments: CUST STATES THAT THE ENGINE HAS A MISS AND HAS NO PULLING POWER ALOT OF SMOKE
Tech Comments: ENG DIAG FOUND CODE P0404 EGR CONTROL CIRCUIT RANGE REPLACED EGR VALVE CLEANED CARBON CLEARED CODES AND RETESTED AND REDROVE ALL OK
1FTNF21P74EB88214 T/F7 F T/BB T/BD T/E A1 T/BE T/YB 20-DEC-2003 13-APR-2004 147214 USA 19 * * * * * * * 37176
AWS Claim Key: 7327589 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2005 Doc #:03769002
AWS Claim Key: 7327588 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02102 - * Name: BILL MARINE FORD, INC. Ph: 937-3823858 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2005 Doc #:03769003
Old 06-23-2007, 10:15 PM
that was one here is another
1FTSF31P14EC82257 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 24-MAR-2004 23-AUG-2004 127473 USA 11 2H01 * * * * * * 9740
AWS Claim Key: 5849224 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00137 - * Name: JERRY'S LEESBURG FORD LINCOLN MERCURY Ph: 703-7770000 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2005 Doc #:12275101
Cust Comments: OPEN CAMPAIGN
Tech Comments: PERFORMED RECALL 05B29
1FTSF31P14EC82257 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 24-MAR-2004 23-AUG-2004 127473 USA 11 * * * * * * * 9740
AWS Claim Key: 6142821 Trx Code: 05S34 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00137 - * Name: JERRY'S LEESBURG FORD LINCOLN MERCURY Ph: 703-7770000 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2005 Doc #:12275102
Cust Comments: ?PERFORM OPEN RECALL
Tech Comments: 1 PERFORMED RECALL 05S34, AND PERFORMED POST ROAD TEST
1FTSF31P14EC82257 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 24-MAR-2004 23-AUG-2004 127473 USA 14 1H03 030008 4C3Z 9F452 A D50 42 12940
AWS Claim Key: 7188552 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 00137 - * Name: JERRY'S LEESBURG FORD LINCOLN MERCURY Ph: 703-7770000 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:12603301
Cust Comments: CUST STATES TURBO PULSE WHEN ACCELERATING WHISTLING AND FLUCTUATES, NOT ENOUGH POWER UNDER HEAVY LOAD WANTS TO DIE
Tech Comments: VERIFY CONCERN LACK OF POWER HESITATION PERFORMED DIESEL DIAGNOSIS PERFORMED DIESEL PERFORMANCE TEST P0404, P0405 PINPOINT AND REPLACED EGR VALVE STUCK RETESTED TO VERIFY REPAIR
1FTSF31P14EC82257 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 24-MAR-2004 23-AUG-2004 127473 USA 14 * * * * * * * 12940
AWS Claim Key: 7188550 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00137 - * Name: JERRY'S LEESBURG FORD LINCOLN MERCURY Ph: 703-7770000 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:12603303
Cust Comments: PERFORMED RECALL 05E15D
Tech Comments: RECALL DONE
AWS Claim Key: 7188551 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00137 - * Name: JERRY'S LEESBURG FORD LINCOLN MERCURY Ph: 703-7770000 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:12603304
Cust Comments: 1 PERFORMED RECALL 59B01A RECALIBRATED MODULES
1FTSF31P14EC82257 T/F7 F T/BB T/CD T/E A1 T/BE T/YB 24-MAR-2004 23-AUG-2004 127473 USA 27 3A15 070102 3C3Z 7H141 AA G29 42 33871
AWS Claim Key: 10663020 Trx Code: S07 Labor Hrs: 2
Dlr Cd-Sub Cd: 09452 - * Name: TED BRITT FORD SALES, INC. Ph: 703-6732300 St:VA Ctry Cd: USA Reg Cd: NA Repr Date:07-NOV-2006 Doc #:57805701
Cust Comments: CK FOR REASON AT TIMES TRANS TEMP GUAGE INOP AND TOW LIGHT INOP. WILL NOT READ INTERMITT
Tech Comments: TRANS FLUID TEMP SENSOR OUT RANGE EEC TEST FOUND CODE P0713,CLEARED CODE,CHECKED FLUID LEVEL FLUID LEVEL GOOD.RAN ENGINE FOR 20 MINS,CHECKED FLUID AGAIN,STILL GOOD.CHECKED TEMP GAGE STILL ON COLD.EEC TEST CODE P0713.TOW HALL LIGHT IN CLUSTER WORKING PROPERLY. DRAINED TRANS PAN AND INSTALLED NEW TEMP SENSOR.CLEARED CODE TOPPED OFF FLUID.AND RAN ENGINE FOR 20 MINS AND TEMP GAGE
Old 06-23-2007, 10:16 PM
Thats Mr. Oil Leak.....
Besides the tranny looks pretty clean. The EGR is pretty common about getting dirty on the 6.0's I don't see anything to be worried about.
Old 06-23-2007, 10:18 PM
That isn't so bad mine was a lemon law recall that I bought before I found this site. It is about twice that long. But ever since I have owned the truck it has ran like a champ. I think they just had to fix all of the bugs. IMHO
