EOT & ECT Average Temps - Ford Powerstroke Diesel Forum
post #1 of 26 Old 11-12-2010, 06:01 AM Thread Starter
Gilstan's Avatar
I recently purchased a 2007 6.0 F-350 and have installed an Edge Insight to monitor the EOT & ECT. Just driving around town and not pulling anything the average difference in the temps seems to be around 8 degrees. While sitting idle the temps will drop to with in 4 degrees. My question is, is this within the norm of what most of you are seeing? What should I expect when towing a 12,500 5th wheel? Also, I plan on installing a turbo back cat delete 4" exhaust and EGR delete in the near future.
Gilstan is offline
post #2 of 26 Old 11-12-2010, 06:02 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Thats perfectly normal. within 15 degrees while cruising is within ford spec
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 26 Old 11-12-2010, 06:04 AM Thread Starter
Gilstan's Avatar
That was quick, Thanks
Gilstan is offline
post #4 of 26 Old 11-12-2010, 10:15 AM
mah77's Avatar
Agreed. On the freeway (55-60), nothing in tow, my ECT sits around 190*, and my EOT around 197*.
06 F250 FX4 Lariat, 35" Nitto Terra Grapplers, 6" Lift Leveled w/Bilsteins, 4" MBRP TB Exhaust w/Cat Delete, Edge Insight w/EGT Probe & Dash Pod, SCT X3 w/SRL Tune From Matt @ Gearhead, Powerslot Rotors, Hawk Pads, Upgraded Oil Cooler Screen, Upgraded Turbo Drain Tube, Upgraded STC Fitting, Upgraded FPR Spring, CAT ELC Coolant, ARP Head Studs, Opti-Lube XPD, Coolant Filter, 45K Miles
mah77 is offline
post #5 of 26 Old 11-12-2010, 10:33 AM
Galaxie's Avatar
Youre all good!
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #6 of 26 Old 11-12-2010, 12:48 PM
topdwg's Avatar
188/190 and 192/193 for me. Before changing out my cooler I was 178/200.
2012 F-350 SRW King Ranch
SOLD - 2004 Lariat F-250 4x4
6.5 Pro Comp Lift W/ Fox Shocks, DeeZee Tool Box, 08 Diff. Cover, 37x13.5/20's Pro Comps, Zoodad Mod, SCT w/custom tunes, 4 in EX., AFE Intake, ARP, Recon Lights, High Idle Mod, RCD EGR Delete, Fumoto Valve, Oil Bypass Kit, 03 Turbo, Yukon Gears, Farmboy Stage II Traction Bars, Dieselsite Coolant Kit, Amsoil, HIDS, Edge Insight CS, PHP FICM
topdwg is offline
post #7 of 26 Old 11-12-2010, 12:53 PM
Galaxie's Avatar
Nice! I am about that same spread on the stock cooler. Only 41k and was flused when I did studs and egr last year at 30k. Flushing and doing ELC as soon as I can get away from work for a bit! Hope to do it in the next week or so.
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #8 of 26 Old 11-14-2010, 04:22 AM
Geoff941's Avatar
Does anyone have any temp numbers while towing? On the interstate with NO load I'm hitting 190 ECT and 195 EOT, but when towing my boat the numbers jump up. Does a 15* or more difference while towing indicate a problem?
The reason I need a Powerstroke
2003 6.0 crew cab DRW
Edge Insight
EGR delete
DFuser coolant filter and EC-1 fluid
Need a BIGGER boat to tow
Geoff941 is offline
post #9 of 26 Old 11-16-2010, 07:57 PM
MoyockPowerstroke's Avatar
I towed a couple of times this summer...both pretty hot days...towing trailer of 11.5-12K...4" lift, EGR cooler in place, no tune. My temps spread was as much as 18*F different on for short burst. I have the VXCF9 strat and did Not get a CEL. My oil got as high as 220 and my coolant was as high as 216...of course the fan kicked on, but those temps are exceptable.
'05 6.0L, 128k miles, Racor CCV6000 Filter, Oil Bypass Filter, Fumoto drain valves, Coolant Filter, ZooDad, HighIdleMod, BullyDog 4" TB, VXCF9 Strat, Edge Insight Gauge, Torque App, Fuel Press Gauge, Upfitters, 4" SJ lift w/Bilstein 5100's, Ride-Rite Airbags, Rough Country Dual Stabilizers, 24" Wipers, '08 Rear Diff cover, Mobil1 Syn 5W-40, 6.4L banjos, Blue Fuel Spring, SS HPOP screen, '08 Mirrors, Zerex ELC.
MoyockPowerstroke is offline
post #10 of 26 Old 11-17-2010, 05:15 AM
Slacker
Evil Eye's Avatar
Quoted: 233 Post(s)
Feedback Score: 4 reviews
Sounds similar to what I got while towing a similar load, although our outside temps were probably higher out here in the desert than what you guys see back in NC.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
