3.5 Dp question
So my buddy came by today and gave me a complete magnaflow turbo back exhaust
should I use the 3.5 downpipe with it or leave the stock one on it. I've heard you can loose pwr from a bigger dp.. Is that true?Thx...Seth |
Use the bigger downpipe, your truck will thank you.
3.5"DP to 4" I think is the best set up for the 6.0 |
The stock dp has a wedge type connector where the cat pipe requires a donut to mate to it. Then there is the pull clamp that pulls them together to make them seal.
The aftermarket dp are also going to be 3.5" till under the floor. They have to be as the turbo and clamp is designed for that size opening and the space available between firewall and engine has about that much room. About the only issue you need to look into is the style of clamp you will have to mate the dp to the rest of the exhaust. I just added a cat test pipe and had to install the mfrs dp to mate to it. The stock dp would have to be cut and the mating flange welded on to mate to the test pipe. I don't have the hardware to perform that in the driveway. |
Some exhaust kits do have 4 inch down pipe (diamond eye)
Hey Seth, are you on quattroworld as well? Your handle looks familiar.
If there is such an application for a 4" dp, is the turbo stock?
The stock turbo has an outlet housing only so big and the clamp works with the outlet. |
Although the outlet on the housing of the stock turbo is right around 3 inch I.D. , you can still benefit from running a larger downpipe with less restriction on a stock turbo. Hope that answers your question.
Afterthought
What's up man.. Yeah I'm on qw
I've got the 4 inch on mine, but be sure you either dent the downpipe or bend the lip back on the bottom of your firewall or you will have a nasty vibration and it sounds horrible.
