Curious how many miles you have seen on a stock 6.0? Stock means no chips, no egr deletes, no exhaust change, no programmer. From factory just as it rolled off the floor--stock! Mine is completely stock and so far I have had to replace injectors and that was it. It has 83,456 miles on it. Like to know what you seen most miles on stock engine. Like to know what I can expect to get out of mine.
There is anothe thread about this but I could not find the link, use the search bar
have an 03 "worst year engine ever" and has 183,xxx miles on it. havent had any problems except injectors right around 100k.
I got 98000 on 03 and never a problem.
i was at ~94k on my 05 when the EGR went to hell, then the head gaskets went 3 weeks later.
135k and no problems that werent owner induced
disreguard last post.... by far no way stock...
My hunting buddy has an 04 with 186,xxx on it and he bought it new. He has added no upgrades whatsoever, same tire size, same wheels, etc.. as it came from the factory with, but he pulls maintenance religiously. He just started having an idle issue last week that we havent fixed yet but he loves it and it has been dependable all the way. My truck is a 06 with 54,xxx and it hasnt given any trouble. (knock on wood)
According to the Oasis, my 04 had Oil Cooler/EGR Cooler/Head Gaskets done at 80k. I'm at 230,xxx now and just had to do a EGR delete and Oil Cooler and Turbo. No Problems between!
I have 41K. Not much has been done. New gasekts, then heads, then EGR, then my cam went. After that I spun a main bearing. Then after that a few push rods bent. So I did a new long block. Then my turbo went. After that my injectors went. I got it running and then the trans went out.
Just kidding - no issues! Many 6.0s running forever. Just fix the EGR and coolant issues! |
