Block Heater Temps...by the hour. - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 41 Old 11-11-2010, 08:24 AM Thread Starter
amdriven2liv's Avatar
Quoted: 4 Post(s)
This morning I plugged the block heater in. My Scangauge read 39 degrees.
1 hour later it was 80 degrees.
2 hours later was 94 degrees.
3 hours later it was 103 degrees.
4 hours later it was 110 degrees.
5 hours later it was 116 degrees.
Yes, 39 isn't that cold to start, but was interesting to see that it went from 39 to 80 in an hour.
Currently my oil temp in hour 3 is 77 degrees. It was 40 at starting point.
Oil temp after 4 hours is 91 degrees.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #2 of 41 Old 11-11-2010, 09:33 AM
Very interesting
2006 cc 4x4,Rotella 5-40,Amsoil bypass filter Dieselsite coolant filter, edge evolution, K&N air filter, high idle mod, zoodad mod, 60 gallon Titan Tank, blue spring kit, Airlift 5000 bags, Bilstein hd shocks, MBRP 4 inch st pipe turbo back, welded egr cooler
rowcoach is offline
post #3 of 41 Old 11-11-2010, 01:22 PM
Kwattro's Avatar
That's actually good data and clever of you to post it up. Helps validate and quantify the use of the block heater in different conditions. Curious to see the values when the temps are in the negative double digits.
The El Cheapo Cooling Filtration DIY - It works!
_________________________________________________
-= 2006 F-350 SuperCrew 4x4 6.0L PSD =-
IIS Stage 1 Turbo, Warren Diesel 155cc/0% Injectors,
Swamps 58v FICM, PHP Atlas 40 Tune, PHP Gryphon Programmer,
5" Diamond Eye Exhaust, DieselSite Coolant Filter,
Knockoff EGR Delete, ARP studs, 33" Toyo MT's
Kwattro is offline
post #4 of 41 Old 11-11-2010, 01:31 PM
Galaxie's Avatar
Its funny you posted this. My truck was at 33* oil and coolant the other day. I had an hour worth of work to do at home before heading to work. I plugged it in for around an hour and i was already in the 70s!
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #5 of 41 Old 11-11-2010, 07:10 PM
89MustangGX's Avatar
Interesting.
My take on this is that plugging in for more than an hour is probably overkill unless you're in a serious deep freeze someplace. Just my opinion...
Adam
89MustangGX is offline
post #6 of 41 Old 11-29-2010, 03:37 PM
Tonka Toy's Avatar
Does the block heater stabilize itself after it gets up to a certain temperature or does it just continuously heat the block?
Can you leave it plugged in all night long and not worry about it overheating?
2005 F350 SRW 6.0L. Exhaust and XCal3.
Tonka Toy is offline
post #7 of 41 Old 11-29-2010, 04:39 PM Thread Starter
Quoted: 4 Post(s)
I have left mine plugged in for more than 10 hours. Problems? None that I have noticed.
Not sure to what temp it will get too. Didn't have the Scangauge last winter. Maybe I'll find out this winter.
post #8 of 41 Old 11-29-2010, 04:50 PM
Fox'sFord's Avatar
I plug mine in overnight to cut down on warm up in the morning, it makes the neighbors happy. Lately the temp has been in the thirties and my insight reads the temps(ect and eot) between 100-110.
Fox'sFord is offline
post #9 of 41 Old 11-30-2010, 05:08 AM
DDBCK's Avatar
Wow, that is some great info. It gets very cold up here in Wyoming. But to leave it plugged in all night might be just a waste of electricity. Thx
2007 F250 XLT
6.0 POWERSTROKE
EGR DELETE KIT
AFE COLD AIR INTAKE
MAGNA FLOW EXHAUST
6" FABTECH DIRT LOGIC 4.0
37/13.5/20 TOYO OPEN COUNTRY
AMP RESEARCH POWER STEP
SCT X3 TUNES BY IDP & GEARHEAD PERFORMANCE
DDBCK is offline
post #10 of 41 Old 11-30-2010, 05:21 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
I usually have mine plugged in for about 3 hrs prior. At 15 degree ambient temp my EOT is about 98.
As to the guy that asked about issues with leaving it plugged in. No nothing to worry about.
I know guys that leave em plugged in for weeks at a time
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
