coolant temps - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-10-2010, 06:34 PM Thread Starter
06six.O's Avatar
coolant temps
i see all the talk about the egr coolers.. whats the normal temp for the truck to run? my coolant is around 180-190 and oil is about 208-216 is that normal or do i need an oil cooler?
06six.O is offline
post #2 of 5 Old 11-10-2010, 06:37 PM
tiny_J's Avatar
the rule is for the not to differ more than 15*...ive only seen mine get to 6 deg differance. i would think you would need to flush atleast. one of the pros will pop in a min an tell you more.
06 F250 King Ranch FX4 Crew Cab
Performance:
Banks Six Gun w/ Banks Iq
Banks High Ram Intake
Zoodad Mod
4" Turbo back Strait Pipe
Exterior:
2" Ebay level kit
295/65/20 Nitto Trail Grappers
KC light bar, 2 KC long range, 2 KC Driving
Omega tri-trump train horn 150psi
Interior:
Rockford Fosgate 3-way door speakers
Rockford Fosgate 10in P3 Shallow Sub w/ 300W Rockford amp
tiny_J is offline
post #3 of 5 Old 11-10-2010, 07:41 PM
turbo347stang's Avatar
So, if I'm reading this right, your minimum difference is 18* and up to as much as 36*? Yeah, that's a problem. Your oil cooler's no longer doing its job like it should and more problems are to come it you don't get on that. I would recommend looking into some BPD products sooner rather than later.
06 F-350 CC, SB, Lariat- Insight CS, High idle, dieselsite coolant filter, 4" Diamond Eye, CAT ELC, 6.4 banjos w/reg kit, SCT w/MKM, SRL, or Looney, Leveled, PHP tuned 48v FICM, HID heads&fogs.
turbo347stang is offline
post #4 of 5 Old 11-10-2010, 09:11 PM
BryanDowdy's Avatar
Your limp mode light should be coming on. I believe it comes on when these is 15* difference and the truck goes into full limp mode around 30-40* difference. Don't quote me on the temps, but I know they are close.
You wont start burning up stuff till around 250 and above on the oil side. But that does not mean you should keep driving it. It needs a VC-9 flush and a new cooler.
'13 F350 CCLB
BryanDowdy is offline
post #5 of 5 Old 11-10-2010, 09:13 PM
BryanDowdy's Avatar
After I did a VC-9 flush and a new cooler, my oil temps are normally 2-3* lower than my coolant.
'13 F350 CCLB
