is this anti freeze good - Ford Powerstroke Diesel Forum
Old 11-10-2010, 11:53 AM
I picked up some Rotella ELC, it says it meets or exceeds the requirements of EC-1. Is this ok to use and do i need to add anything to it for ph,thanks
Old 11-10-2010, 12:06 PM
yes its ok to use, i have it in my rig. no need to add anything except for distilled water (assuming you bought concentrate).
Old 11-10-2010, 12:44 PM
That's a good coolant, but I'd recommend doing a complete cooling system flush before adding it. And don't mix the gold coolant with the ELC.
Old 11-10-2010, 12:50 PM
That's fine to use, but as said do a cooling system flush with both VC-9 and Restore before switching to clean the cooling system out good.
Old 11-10-2010, 01:09 PM
ok thanks, i got a coolant filter and a egr delete on the way,so i will do a good flush then,is the restore the same blue stuff in the silver container you get from the local auto parts store.
Old 11-10-2010, 09:23 PM
NO ... Restore is a semi-clear / semi-thick liquid in a gallon bottle ... made my Fleetguard. Usually sold through Cummins Dealers. Expect to pay around $ 30.00 for 1 gallon. This is the stuff that eats the junk left over from the Gold Coolant.
