SCT Fitting Falure Chances - Ford Powerstroke Diesel Forum
post #1 of 34 Old 11-08-2010, 06:50 PM Thread Starter
Galaxie's Avatar
06 with 41k..... How often are these fittings failing? Is it an amlost all will fail thing or hit or miss?
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #2 of 34 Old 11-08-2010, 06:56 PM
FordPwrStroke4Life's Avatar
are you still under waranty if so see if ford will do it for you for free
2005 F250 Lariat 6.0 Powerstroke
Crew Cab 4X4 FX4
Upgrades to date:
Bullet Proof Diesel EGR Cooler
Bullet Proof Diesel Bumper Mount Oil Cooler
STC Fitting Upgrade
High Idle Mod
Upgrades Pending:
EDGE CTS Monitor w/ EGT Probe
SCT Tuner w/ Custom Tunes
Coolant Filter
AFE Stage 2 Si Intake
Powermax Turbo
4" Turbo Back Exhaust
FordPwrStroke4Life is offline
post #3 of 34 Old 11-09-2010, 03:19 AM
diablos30's Avatar
Quoted: 31 Post(s)
i believe ford is only going to replace it if it failed, i don't think they will replace it as a preventative measure.
as for if it will last or not...roll the dice. however, they can fail spectacularly and cause damage to the rear cover.
diablos30 is offline
post #4 of 34 Old 11-09-2010, 04:30 AM
bondsman's Avatar
My 05 made it 175k and I just changed it because I am doing head studs/gaskets. My son's 06 made it to 75k before it left him stranded. So I guess it is just luck of the draw...
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #5 of 34 Old 11-09-2010, 07:04 AM
mine failed at 132,000
dhale101 is offline
post #6 of 34 Old 11-09-2010, 07:52 AM
Snake's Avatar
Quoted: 46 Post(s)
Mine failed at 60k. My suggestion would be to tell the dealership you're having hot start issues and see if you can get the branch tube, STC fitting, and HPOP replaced under warranty before you're stranded
Snake is offline
post #7 of 34 Old 11-09-2010, 09:49 AM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
My original failed around 24k... The dealership couldn't figure it out despite me giving them the TSB... On the 4th trip back, they finally figured it out and replaced it. This time, I was a touch over 30k miles and they charged me my deductible. I haven't gone back to that POS dealership.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #8 of 34 Old 11-09-2010, 03:44 PM
Mine had 55K when it failed
Former 6Leaker owner
Newman is offline
post #9 of 34 Old 11-09-2010, 05:24 PM
i made it 144k before i changed mine. general consensus is just do it i think before it causes damage
Crew Cab 4X4 FX4
Upgrades to date:
STC Fitting Upgrade
High Idle Mod
Upgrades Pending:
Coolant Filter
Powermax Turbo
post #10 of 34 Old 11-09-2010, 05:34 PM
LNS4x4's Avatar
mines went out at 91k
2005 6.0 PSD XLT SD FX4 CC LB
Engine:
SCT, SRL, Atlas 80, Arp's, Bulletproof Oil cooler w/ Cold weather package, All aluminum radiator, Bulletproof water pump, Sinister Full Delete, 4" Mbrp turbo-back, Banks Techni-Cooler, Banks intake, Edge insight CTS, Diesel site coolant filtration, CCV Mod.
Suspension:
2.5 Icon Leveling kit, 5" Icon rear block, Pure Performance adjustable trackbar, King shocks, PMF 3 link.
LNS4x4 is offline
