OK, ready to do coolant flush
I have.......
2-qts. VC-9 1-gal. Restore 1-new t-stat w/housing and o-ring 1-replacement coolant filter Have questions. Is there an order to flush coolant? IE: vc9 first and restore second---or vica-versa. Still unsure which coolant to use, Ford Gold, Cat ELC, Prestone GO-5. I am leaning away from the Ford Gold. Which would be the best? I spoke to a dealer service tech. He said the problem with the leaking coolers is the clogging at the oil cooler inlet, which causes overheating and splitting of the EGR coolers. I have had the coolant filter on this truck from 800 miles new. He said I shouldn't have a cooler problem since the coolant looks very clear. Anyway, the questions above are my only stumbling blocks to getting this done, as I want to do the best for my truck. It is a 2006 with 54,000 miles. I think I will replace the hoses also......... |
anything cat ec-1 rated
So the Cat EL is the good stuff? Is that the red product? and I mix it with water 50/50?
yes you can use the cat brand, but the "cat ec-1" rating is whats important. dont get hung up on color (although most elc's tend to be red), concentrate on the ec-1 rating. fleetrite, cat, rotella, and zerex are the names that come to mind and what most use. you should be able to find them at an international dealer, cat dealer, online, or napa.
i recommend buying the concentrate that you mix as its a waste to pay for half of the bottles worth of water. |
You mentioned Zerex, would that be the GO5 concentrate? I just spoke with the CAT dealer here, he said the concentrate EL is no longer available, only the 50/50..........
Have your CAT dealer try part # 238-8647. I just bought 4 gallons this morning from my local Cat parts dept. This is the concentrate ... NOT the 50/50 diluted.
The parts guy looked it up, no longer made, he said. Possibly your dealer has a stock of of it.
I just picked up the concentrate from the local Cat dealer in town 3 days ago. I think your Cat dealer is smoking weed. You can't tell me guys that are servicing heavy equipment using gallon after gallon of coolant are going to buy a 50/50 mix. They still make the concentrate, maybe he can't find it but there is no reason for Cat to stop making it.
