Temperature gauge question
In the morning I start my truck to warm it up before I leave home. It runs for about 10 min. When I get in the truck I look at the gauges and the Tranny temp is right at normal, but the water gauge isn’t measuring at all, the needle is resting at the bottom of the gauge. As I start down the road the truck doesn’t feel right, it feels like it isn’t shifting correctly. As I get a mile or two the temp needle comes up and runs in its normal position and runs perfectly. I find this all very weird, I could understand if the tranny temp was in the cold position and the tranny ran rough, but that’s not the case. Is there a direct correlation between the engine temp and the way the transmission shifts, or do I have two separate problems. I noticed over the weekend dried up antifreeze around and below the degas canister. In the last two years I’ve replaced the Oil cooler once and EGR cooler twice. I was even told they swapped out my head bolts, but I seriously doubt it. Any insight on this would be great.
Have you changed the trans filter the little roll of T/P up front Idle time of 10 min is to long 1 to 2 min or you will be having turbo and EGR valve problems. 2 stroker |
To the OP does it ever have problems starting or a long crank? |
If you don't want this to keep happening you need to stop using Ford's Gold coolant and switch to ELC coolant, I don't care what Ford or their mechanics say about this. You also need to get an Edge Insight or something that will let you monitor your coolant and oil temps to know if your cooler is clogging before you blow something else. As for the temp gauge they are pretty much a joke but either your sensor is bad or your thermostat is stuck open. |
2 Strk.. There is coolant in the degas canister in the morning. This morning it was tough to start and idled rough and smoked a little. That being said it was 40deg out. Also, In the past when both coolers were out it puked fairly often, now it pukes fairly infrequent now. Although if I was to tow I'd probably be singing a different tune. I'm really concerned as to why the temp needle doesnt move until I get a couple miles down the road, the truck runs like crap until the needle begings to move. Once warmed up the truck runs great.
I purchaed this truck a year old and I've had nothing but problens since day one. I've owned 6 Ford trucks and due to the piece of cr@p 6.0 motor it's been the worse vehicle I've ever owned. |
thats where mine reads
The needle won't move until coolant temps are above 100 deg. Get an insight.
should take 10 min of warmup and driving down the road a few miles to bring the engine temp to 100deg
