shops that do headstuds - Ford Powerstroke Diesel Forum
Old 11-06-2010, 02:37 PM
Is it normal that a shop charge a $2000 core on the heads when the do head studs?
also anyone ever use rcd to do there head stud install?
Old 11-06-2010, 07:52 PM
I am not sure what you are talking about with this $2000 bit. Can you explain better?
Old 11-06-2010, 08:02 PM
Are you replacing the heads as well? Just to do head studs you shouldn't have a core charge at all. Unless you messed your heads up you shouldn't even be replacing your heads just to install head studs.
Old 11-07-2010, 06:35 AM
i called a shop to do my head studs and they want $2000 for heads because they give me new heads and if they cant use mine i pay 2000
Old 11-07-2010, 06:40 AM
2k for heads or headstuds? Im confused..and for labor or the parts? or both?
Old 11-07-2010, 12:01 PM
Is the truck still running? Are you just wanting head studs before you blow head gaskets or have you already blown head gaskets and they are afraid you warped your heads. If every thing is running fine and you are just simply wanting head studs (ARP's etc...) before you do blow a head gasket then there is NO need for new heads. There should be NO reason for that shop to even think about putting new heads on your truck. If I am understanding you correctly, you might want to RUN to another shop and get second opinion.
Old 11-07-2010, 01:30 PM
(If I am understanding you correctly, you might want to RUN to another shop and get second opinion.)
What he said X2
Doug
Old 11-07-2010, 04:28 PM
I was told the same thing from RCD. They said if ur heads were bad you would have to pay the 2000.00 core charge for the new heads. I can't understand how they could be so bad that they couldnt be milled down.
Old 11-07-2010, 04:34 PM
a core charge is something that should be repaid once the core(old part) is returned. I don't know if maybe they are ordering new heads before you bring it in or what? Kinda confusing to me even if the heads were replaced you shouldn't be paying for a core charge because they take your old heads and return them to whereever they were bought.
Old 11-07-2010, 05:14 PM
From the very beginning of this thread when I saw RCD I got nervous for ya. I have read to many posts on here about problems from them. Go get a second opinion.
