ECT Question
I have a 06 and it has the latest flash. My question is according to my insight my ECT usually stays right at 180. Now in the summer when it's in the 90 or 100's the temp will go in the 190 range but normal driving on the highway it runs right at 180. Is this normal? I tried a search and I noticed most say there's runs 190+. My EOT according to my insight runs about 8-10 degrees hotter than my coolant. Thanks for any help.
Kind of low, but I wouldn't worry too much about it. I'd rather it be a little low than high
. Mine runs between 185 and 200 depending on the engine load. The EOT looks great!
There's a thread that is pretty close to your's:
EOT and ECT wont get warmed up?? The general consensus on that one is that the thermostat is stuck open ![]() My number's are real close to what you were sayin' |
I was just wondering if maybe my insight might be off or just my thermostat might be screwed up?
I know I can watch my insight running down the highway and it will be 179-180 that is unloaded just cruising around. It will climb some with a load on the motor but not alot.
Actually the diesel runs better with some heat in it. That's why they make a 203* thermostat. At 180 there is no reason to panic but it might run a little better and get a little better mileage if you get a little more heat in it. Thermostats are cheap and easy to change. |
Thank you for the replies. One more question. I went out and looked at where the thermostat is located. Will I lose much coolant when pulling that hose off?
Drain 2 gallons will get you below the area in question. I drain into milk jugs. But the jugs I use are brand new, never been used. So keep it clean and pour back in when job is done.
Is there a drain plug somewhere? Sorry for all the questions.
Yes, see it right behind the brass nut? It's white and plastic. The little drain tube is right there. Bottom of Radiator. Towards driver side.
