Oil Bypass nightmare - Ford Powerstroke Diesel Forum
post #1 of 31 Old 11-04-2010, 01:37 PM Thread Starter
Angry Oil Bypass nightmare
So i bought pieces from amsoil to make my oil bypass kit. The only peice i didn't buy was the hose (reason being its expensive as **** from them). That being said i put it together, went to Lowes and bought 1/4 ID and 1/2 OD (same as amsoil size) hose. The hose was "fuel line" hose... sturdy rubber, and i figured it would hold up to the corrosion and pressure. WRONG today the truck literally blew a hole in the hose near the fitting. shut it down when pressure dropped, and got it towed... this is the 2nd time i have had the truck towed in a week for oil being spewed out. can anyone recommend a GOOD hose that will hold up to the pressure.. before i throw this **** away or ebay it minus the hoses.
Looking for help here, already called ford and told them order the OEM caps to return the truck to stock. i've spent prolly $110 on oil... all to be spilt out onto pavement.
1st time was my fault.. used a hose clamp thinking it could hold pressure, 2nd time the hose literally burst in middle... no ryhme or reason here.
brianjbeach85 is offline
post #2 of 31 Old 11-04-2010, 01:46 PM
shaking things up
jethro's Avatar
umm dont blame the hose as it was not rated for that when you put pressure to fuel line it will break if it is not rated hose. so use the correct hose and it will all work out just fine can't blame anyone but yourself for that one plus fuel is not hot when passed through the hose and heat will deteriorate the line as well
389.14 HP 726.00 TQ
96 f-350 7.3 with a 5 speed
3 in DP
4 in ex. to 5 in aussies
custom traction bars
TW chip 6 pos
IDM mod
SD IC
HPX
D66
casserly 2's
custom fuel with an AIRDOG 2
910's
*17 TE modded hpop
ebpv gutted
pedestal gutted
gutted ccv elbow
clutch pedal fix
facebook- Graham Maxwell
jethro is offline
post #3 of 31 Old 11-04-2010, 01:49 PM
majorleaguebass's Avatar
napa is ur friend
2015 F350 Platinum
TK Performance
4" Rancho w/ Fox Shocks
24" American Force Independence
37" Toyo Mt
Custom Bullydog Cheats
5" Flo-Pro
H&S Intercooler Upgraded Pipe
majorleaguebass is offline
post #4 of 31 Old 11-04-2010, 01:49 PM Thread Starter
i agree can't blame anyone but myself, just very frustrating sitting on side of road. im gonna call amsoil and check on hose.. not sure where hell u would get another hose like that. anyone else with suggestions maybe a place to get the hose other than amsoil??
post #5 of 31 Old 11-04-2010, 01:49 PM
elm302's Avatar
Feedback Score: 3 reviews
Get hydraulic hose it rated at like 5000 psi
2003 F350 Lariet Leveling kit eagle 197s MBRP stainless tb to 6" stack Sinister coolant kit Sct with Looney and Innovative High Idle fog light and bright box mod soon to come Edge CTS PHP ficm tuning and Cab lights
elm302 is offline
post #6 of 31 Old 11-04-2010, 01:53 PM
troid123's Avatar
Send a message via AIM to troid123
a steel braided hydraulic hose will work best. You got what was coming buying cheap fuel line hose from lowes...
2006 F250 CC Short Bed King Ranch 4x4 (109,000 miles)
4" Turbo Back w/ 6" Tip
SCT x3 w/ Custom Tunes From DJ's/Innovative
03 turbo
Eclipse Navigation/DVD/CD/MP3 w/ Rear Camera
Rear DVD/MP3/CD Entertainment System
Escort Passport SR7 Built In Radar Detection System
K & N Cold Air Intake w/ S&B Replacement Filter
Roll-N-Lock Retractable Bed Cover
Nitto Trail Grappler LT295/70R18
***SOLD 10/31/11***
New Truck:
2011 Ford F-150 Limited 6.2L Super Crew
troid123 is offline
post #7 of 31 Old 11-04-2010, 01:59 PM Thread Starter
i'm not saying i don't spend money on the truck, because i do. the only downside was no one would tell me fuel line wouldn't hold up.. everyone i asked said oil line will work... i blame them, and i am ordering the amsoil hoses.. very expensive, but they wont sell a product to me that isnt rated at it...
post #8 of 31 Old 11-04-2010, 02:02 PM
Go to summit racing and buy some push lok hose and fittings.
PsRumors is offline
post #9 of 31 Old 11-04-2010, 02:05 PM Thread Starter
that rated for this application? and will it be same thread size i need for the 1/8' npt elbow fittings on filter assymbly/filter and filler caps?
post #10 of 31 Old 11-04-2010, 02:13 PM
scotty2280's Avatar
how much into this ''home'' kit are you into it now?
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
